Gimp help browser on high rez monitor
2020-03-25 15:48:49 UTC (about 5 years ago)
***UNCHECKED*** Gimp help browser on high rez monitor
My monitor is 3840 x 2160 on a Mac. The help browser offers great help, but it's difficult to read as the font is so small on my monitor. I can't find a way to increase the font size other than changing the screen resolution. Is there a way to do that within Gimp?
Thank you
PJW
PeterJWhite (via www.gimpusers.com/forums)
2020-03-25 16:52:02 UTC (about 5 years ago)
Thank you
PJW
Maybe someone can give advice on that resolution problem. If not there is the Gimp 2.10 help in PDF format here:
http://gimp.linux.it/www/meta/
gimp-help-2.10-en.pdf 42 MB 1000 pages, indexed and searchable.
2020-03-25 17:44:01 UTC (about 5 years ago)
Got it!
Thank you very much
PJW
Ken Moffat via gimp-user-list
2020-03-25 19:39:21 UTC (about 5 years ago)
Thank you
PJW
I use linux and compile gimp myself, using firefox to open the help. So I have no idea if this will work with whichever browser engine you are using, but 'Ctrl' and '+' let me zoom in , 'Ctrl' and '-' let me zoom out.
ĸen
When alle is ſayed and all is done, ye must chooſe your faces wisely,
for soon enouff ye will be playing with fyre."
  The Nice and Accurate Prophecies of Agnes Nutter, Prophecy 5004
2020-03-25 20:02:05 UTC (about 5 years ago)
ĸen
Hi Ken,
On a Mac it's Command + or Command - to zoom in or out. For whatever reason it doesn't work with the GIMP help browser. But now that I have the GIMP help as a PDF I'm all set.
Great software. I just need to learn its secrets.
Thank you,
PJW
2021-07-10 16:06:53 UTC (almost 4 years ago)
Monitor
2021-07-10 16:07:56 UTC (almost 4 years ago)
2021-07-10 16:08:51 UTC (almost 4 years ago)
Monitor
