Where was GIMP installed?
Where was GIMP installed? gooroo via gimp-user-list 14 Feb 19:05
  Where was GIMP installed? Michael Schumacher 14 Feb 19:22
  Where was GIMP installed? Jernej Simončič 14 Feb 19:33
  Where was GIMP installed? rich404 15 Feb 13:42
2020-02-14 19:05:18 UTC (about 5 years ago)
I installed it today, but no desktop shortcut to it was created. And using the Windows 10 'search' does not locate it no matter where I start!
I cannot use the program, if I cannot locate it.
Ed Kivi ... aka "GooRoo"
Confirmed Gruntzaholic ... no remedy possible!
Happy Gruntzing!!!
2020-02-14 19:22:45 UTC (about 5 years ago)
Works fine for me. What exactly did you install?
-- Regards,
Jernej Simončič
2020-02-14 19:33:20 UTC (about 5 years ago)
The shortcut is in the Start Menu. If this is the first time you installed GIMP, it should be at the top, otherwise look under G.
< Jernej Simoni ><><><><>< https://eternallybored.org/ >
It's always darkest just before the lights go out.
       -- Clark's Law
2020-02-15 13:42:46 UTC (about 5 years ago)
Windows search? You almost need to already know the location.
However, the search: https://i.imgur.com/cr40rUa.jpg
The shortcut: https://i.imgur.com/XfS9T9y.jpg
Why did you not get a desktop shortcut when you installed Gimp? It is right on the last page of the ***customise*** install option and off by default.
