Melt Script?
Melt Script? tz20@gmx.de 13 Jan 12:10
  Melt Script? rich404 13 Jan 13:27
tz20@gmx.de
2020-01-13 12:10:53 UTC (about 5 years ago)
Melt Script?
Is there a working melt script/plugin for gimp 2.10? like melt_me for gimp 2.8)?
2020-01-13 13:27:45 UTC (about 5 years ago)
Melt Script?
Always helps if you give Operating System. Assuming Windows (if using linux let me know)
The Melt-Me script uses two plugins displace and solid-noise which have been replaced in Gimp 2.10 by GEGL procedures. You can get it to work by using the old plug-ins from Gimp 2.8 displace.exe and noise-solid.exe These in the attached zip. Unzip and put the .exe files in C:\Users\"yourname"\AppData\Roaming\GIMP\2.10\plug-ins and the melt-me script in C:\Users\"yourname"\AppData\Roaming\GIMP\2.10\scripts. Find in the Animation menu. Just made a small gif. this one https://i.imgur.com/qLOIQYS.gif
An alternative might be gmic_gimp_qt plugin www.gmic.eu In the sequences section Spatial Transition. Transitions between the image and a transparent layer (or another image). Example gif https://i.imgur.com/fnRZWaW.gif (transparency might show black depending on browser)
Attachments: * https://www.gimpusers.com/system/attachments/1333/original/melt-me-with-plugins.zip * https://www.gimpusers.com/system/attachments/1334/original/gmic.jpg
