Re (2): Re (2): Eraser Problem
Re (2): Re (2): Eraser Problem peter@easthope.ca 06 Aug 20:21
  Re (2): Re (2): Eraser Problem Ken Moffat via gimp-user-list 06 Aug 21:04
peter@easthope.ca
2019-08-06 20:21:49 UTC (over 5 years ago)
Date: Tue, 06 Aug 2019 15:41:22 -0400
If the current layer has an alpha channel, ...
According to the channel panel (or was that chunnel tunnel? Something like that.) for which a screenshot is posted, the alpha channel exists.
and "anti-erase" is not set in tool options,
Will have to look for that next time GIMP is running. Recently the system was upgraded from Debian 9 to 10. As you see from the screenshot, the panels are now almost exclusively various shades of grey text and icons on a darker grey background. >8~( (Is this new dis-feature in Debian only? Upstream release? I'm trying to imagine a justification.)
Consequent to "grey everywhere", I might have difficulty recognizing whether "anti-erase" is not set or not not set. Certainly will look.
If the image is in Index mode rather than in RGB or greyscale mode ...
Greyscale mode. Also evident in a panel in the screenshot.
If all else fails I can at least use the clone tool to get a not-too-bad result. =8~)
Thanks for the help, ... P.
https://en.wikibooks.org/wiki/Oberon
Tel: +1 604 670 0140            Bcc: peter at easthope. ca
2019-08-06 21:04:15 UTC (over 5 years ago)
Edit -> Preferences -> Interface -> Theme
ĸen
One pill makes you larger, And one pill makes you small.
And the ones that mother gives you, Don't do anything at all.
Go ask Alice, When she's ten feet tall.
               -- Jefferson Airplane, White Rabbit
