Tiff compression options
Tiff compression options cedric 16 Apr 22:46
  Tiff compression options Eric P 16 Apr 23:57
cedric
2005-04-16 22:46:45 UTC (about 20 years ago)
Reading Tiff specs for Scribus Team, we saw that Tiif could have JPEG compression. We add a simple question : is gimp implementation of Tiff jpeg compression lossless ? And in which case use one or another compression options ?
regards. Cedric
Eric P
2005-04-16 23:57:50 UTC (about 20 years ago)
jpeg compression is lossy by definition. There is no such thing as lossless jpeg compression.
Personally, I only LZW (which is lossless) for tiff. I cannot think of any reason why you would ever want to use jpeg compression for a tiff over a straight jpeg format. I've had zero experience experience with the Pack Bits and Deflate options.
On a side note, at work we have high spec color laser jet printer that happens to have scanning capabilities as well. For some reason, the tiffs it creates are tiff w/jpeg compression with NO option to change it to other any other compression type or even muck with the jpeg compression setting. I noticed that the Gimp doesn't give any option either for the jpeg compression setting when saving as a tiff.
regards. Cedric
