Can not reset toolbox to default
7 of 7 messages available
Can not reset toolbox to default Kotte 26 Feb 19:39
  Can not reset toolbox to default rich404 26 Feb 21:03
   Can not reset toolbox to default Kotte 27 Feb 11:27
    Can not reset toolbox to default rich404 27 Feb 13:11
     Can not reset toolbox to default Kotte 27 Feb 19:30
      Can not reset toolbox to default rich404 27 Feb 21:11
       Can not reset toolbox to default Kotte 28 Feb 09:25
2019-02-26 19:39:33 UTC (about 6 years ago)
I accidentally closed down my toolbox, and when I opened it again, I could only see the top half of it. I can select the tools I want but I can't, for example, change the settings for opacity and such from the toolbox. It only says that I can "drop dockable dialogs" in the area of the toolbox where there used to be multiple settings.
When I looked up how to reset toolbox settings, it said that I first had to go to "Edit" and then press "Preferences", but I really can't find that. Where "Preferences" is supposed to be, I can chose wether to activate voice directing or not (I use a mac).
I use Gimp 2.8.16 Thankful for help
2019-02-26 21:03:28 UTC (about 6 years ago)
Preferences is towards the bottom of the Edit menu
Click on that to get the preferences dialogue
Find the Window Management Section
Click on Reset Saved Window Positions to Default Values
Click OK and restart Gimp see screenshot
You will be in 3 Window Mode. Gimp Windows menu and Enable Single Window Mode does what it says.
2019-02-27 11:27:53 UTC (about 6 years ago)
It isn't there. I can't find any label that says "preferences", not near the botom nor anywhere else.
2019-02-27 13:11:04 UTC (about 6 years ago)
You do not have an EDIT menu???? OK, you have really screwed up Gimp.
Find your Gimp profile: Are you using linux? Gimp 2.8.16 suggests ubuntu In you home partition, find the hidden folder /home/name/.gimp-2.8/ and rename it to disable . /home/name/.gimp-2.8-backup
(Windows is C:\Users\"yourname"\.gimp-2.8 -> C:\Users\"yourname"\.gimp-2.8-backup )
Start Gimp up and it makes a new default Gimp profile.
2019-02-27 19:30:44 UTC (about 6 years ago)
No, I have the "Edit" menu, it's "Preferences" that I can't find.
2019-02-27 21:11:33 UTC (about 6 years ago)
Sorry I can not help then. You have nothing like the Edit menu I posted as a screenshot in the earlier post. Maybe your computer display is too small and the menu runs off the bottom.
Do what I said last post and backup your gimp profile, Run Gimp to make a new one. Gimp will be as first install.
bye.
2019-02-28 09:25:23 UTC (almost 6 years ago)
bye.
Somehow it solved itself when i accidentally created a big enough file to crash Gimp... XD Thank you anyway. :)
