Suggestion for opening raw images
Suggestion for opening raw images Rick Kline 30 Jan 19:35
  Suggestion for opening raw images Guy Stalnaker via gimp-user-list 30 Jan 19:39
  Suggestion for opening raw images Tobias Jakobs via gimp-user-list 31 Jan 12:22
Rick Kline
2019-01-30 19:35:33 UTC (about 6 years ago)
Starting a new thread instead of getting this one lost in the last conversation.
Thanks for the suggestions, Liam and Guy. I was at least able to access the PDS (NASA’s Planetary Data System) .img image in GIMP 2.8.20 (!) by changing the image file type to .data.
Unfortunately, there’s no bit depth parameter available. How difficult would it be to provide that in the “Load Image From Raw Data” GUI? P’shop provides the following in their "Photoshop Raw Options" dialog:
If there was even just an option to choose 8-bit or 16-bit image depth, that’d be a big help.
Many thanks.
Rick Kline Data Manager (ret.)
Spacecraft Planetary Imaging Facility, Cornell University
* * ** *** ***** ******** ************* ********************* It’s better to wave at a stranger than to ignore a friend * * ** *** ***** ******** ************* *********************
2019-01-30 19:39:58 UTC (about 6 years ago)
Rick,
GIMP 2.8.x is 8-bit not 16-bit capable. To get 16-bit capability you need the new 2.10.x version. That's what I have and it does, in that dialog, have options for bit-depth (including Endian options).
Guy
Many thanks.
“Happiness is the meaning and the purpose of life, the whole aim and end of human existence.”
― Aristotle
2019-01-31 12:22:23 UTC (about 6 years ago)
Hi Rick,
as Guy already wrote, Gimp 2.8 only supports 8-bit. Gimp 2.10 supports 16-bit as internal format and in the raw loader. And perhaps you are interested, Gimp 2.10 has support for the HGT file format, gathered by the Shuttle Radar Topography Mission (SRTM). I blogged about it here: https://dablogter.blogspot.com/2018/01/gimp-now-supports-hgt-file-format.html
And I have an blogpost how to import the NOAA GLOBE elevation files here: https://dablogter.blogspot.com/2018/09/howto-open-elevation-data-from-noaa.html
What is missing is import of 32-bit float values in the "Load Image From Raw Data"-plugin. I opened a feature for that: https://gitlab.gnome.org/GNOME/gimp/issues/2804
Do you have a link to one of thePDS images?
Regards, Tobias
Am Mi., 30. Jan. 2019 um 20:35 Uhr schrieb Rick Kline :
Many thanks.
