Tutorial: Create a nice oilpainting from a photo
Written by , translated by redforce · Created on Sep 15, 2008, last updated almost 11 years ago CC BY-NC License
In this tutorial our user t0bias shows you how to create a fantastic looking oilpainting from a photo. Enjoy!
    To get a usable size to apply on the tools used, I am going to use a factor “x”. x can easily be calculated on an image with a 4:3 aspect by
    just taking 1% of the longer side of the image. E.g. if your image has a size of 800*600 pixels, x would have a value of 8.
    First, we are going to slightly adjust brightness and contrast be 10% “Colors” → “Brightness / Contrast”
    Brightness: +10%
    Contrast: + 10%
    Now let’s make the colors a bit more intense
    “Filter” → “Increase” → “Unsharp Mask”
    Radius: 1x
    Amount: 1
    Threshhold: 0
    In order to get the best possible effect on the image, we’re going to reduce the amount of colors
    “Colors” → “Posterize”: Colors: 3 or 4 (prior to GIMP 2.8: Colors: 12)
    If the name of the layer in the “Layer”-Dialogue should be printed in
    bold, do
    “Layer” → “Transparency” → “Add alphachannel”
    Now go back to the “Layer”-Dialogue, duplicate the layer by right-clicking on the active layer and choosing “duplicate Layer”. Then hide the upper of the two layers by clicking on the “eye”-symbol on the left. Before proceeding, make sure the lower layer is active again!
    Use the Blur-filter to make the colors merge at the edges.
    “Filter” → “Blur” → “Gaussian Blur”:
    Radius: 1x
    Method: RLE
    Next choose
    “Filter” → “Artistic” → “Gimpressionist”
    and use the following settings:
    Presets
    → Feathers
    Paper
    → Scale: 1x
    Orientation
    → Directions: 6
    → Start Angle: 0
    → Angle Span: 120
    → Orientation: Adaptive
    Size
    → Sizes: 4
    → Minimum Size: 3x
    → Maximum Size: 8x
    → Size: Adaptive
    Placement
    → Placement: Randomly
    → Stroke Density: 36
    The contours of the strokes are a bit hard, so reduce them by doing “Colors” → “Color to Transparency”: Color: #bababa
    In the “Layer”-Dialogue, add a new layer and choose “Filling” → “White”, next move the newly created layer to the very bottom.
  11. 11
    Now unhide the hidden layer in the “Layer”-Dialogue.
  12. 12
    Now draw the outlines of the shape by doing
    “Filter” → “Find edges” → “Neon”
    Radius: 0.5x
    Intensity: 0%
  13. 13
    We don’t want any colored lines, so choose
    “Colors” → “Desaturate”: Grauwert: Average
    to remove the colors.
  14. 14
    Next, we invert the colors in order to make the white lines become black “Colors” → “Invert”
  15. 15
    We don’t want any gray tones, but black and white ones, so do “Colors” → “Threshold”: Move the handle about in the center of the color-bar or wherever you think the shape is clearly drawn by the lines or just leave the default
    settings.
  16. 16
    It should look like this now:
  17. 17
    Next we are going to make the lines “pencil-like”.
    “Filter” → “Artistic” → “Van Gogh (LIC)”
    leave any settings at the default values
  18. 18
    Remove the white background-color “Color” → “Color to transparency”: Color: #ffffff
  19. 19
    Now use the rubber-tool to remove artefacts, just keep the “pretty” lines.
  20. 20
    Finish the painting by choosing “Overlay” for the active layer in the “Layer”-Dialogue.
This topic (Create a nice oilpainting from a photo) has been rated 5.0/5.0.
John Henry
almost 11 years ago
BTW, for English readers, Step 13: Entsättigen is Desaturate (according to Google Translate), and Step 15: Schwellwert is Threshold.
John Henry
almost 11 years ago
Unable to do step 4 under GIMP 2.8. "“Colors” → “Posterize”
Colors: 12". It's done by Color Level now. 3 means 2^^3=8, or 4 for 16. Can't specifiy 12.
unni member for over 13 years unni 2 comments rated this topic with 5/5
almost 12 years ago
Excellent tutorial. My image is attached
dr_who rated this topic with 5/5
over 14 years ago
thx for a really useful tutorial! always looking for new things to try with my pictures — and new things to learn.
Jason
almost 15 years ago
Anyone ever seen any good scripts out there that do this? It's a good effect, but would be nice to have a plugin or something for slight adjustments.
replica watches
over 15 years ago
I'm not a troll, but this is bad taste. If you want nice oilpailts, make it with real brushes and true oil paint...
François
over 16 years ago
The name you give me is not good taste either.
Yes we live in a relatively free world. It is the reason why I thought I was allowed to post my aesthetic point of view.
Michiel
over 16 years ago
I think that Francois is a asshole. I has nothing to do with bad taste. This tutorial is all about how to make an oil painting NOT if it can replace oil paintings. If people want to create oil paintings from a photo then they should be allowed. We live in a FREE world!!!!
Francois member for almost 17 years Francois 31 comments
almost 17 years ago
What about creating a nice photo from an oilpaint?
Seriously, I'm not a troll, but this is bad taste. If you want nice oilpailts, make it with real brushes and true oil paint...
about 17 years ago
Its a similar effect but imo this one looks cooler then the one under filters ;)
Youdontneedtoknow
about 17 years ago
Very nice. Although, the Oil Paint effect thing under filters works just the same. :)
residentevil5 member for about 17 years residentevil5 1 comment
about 17 years ago
I could get most of it.......
Robert
about 17 years ago
The final result it's very nice!!
Tom
about 17 years ago
I think the Unsharp Mask is under "Filters" > "Enhance"
