Error trying to compile Perl for gimp 2.0
Error trying to compile Perl for gimp 2.0 Rikard Johnels 07 Apr 16:15
  Error trying to compile Perl for gimp 2.0 Owen 08 Apr 13:08
Rikard Johnels
2005-04-07 16:15:11 UTC (about 20 years ago)
Why cant i compile?
rikjoh@sparhawk:~/Downloads/Gimp-2.0> perl Makefile.PL checking for gimp-2.0... no
checking for gcc... cc
checking for C compiler default output... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether cc accepts -g... yes checking for cc option to accept ANSI C... none needed checking for gimptool-2.0... /opt/gnome/bin/gimptool-2.0 checking for GIMP - version >= 2.0.0... no *** Could not run GIMP test program, checking why... *** The test program failed to compile or link. See the file config.log for the
*** exact error that occured. This usually means GIMP was incorrectly installed
*** or that you have moved GIMP since it was installed. In the latter case, you
*** may want to edit the gimptool-2.0 script: /opt/gnome/bin/gimptool-2.0 configure: error: ** unable to find gimp, make sure it's in your path (version 1.3.15+ required!)
rikjoh@sparhawk:~/Downloads/Gimp-2.0> rpm -q gimp gimp-2.2.4-1.guru.suse92
rikjoh@sparhawk:~/Downloads/Gimp-2.0> rpm -q gimp-devel gimp-devel-2.2.4-1.guru.suse92
rikjoh@sparhawk:~/Downloads/Gimp-2.0> file `which gimp` /opt/gnome/bin/gimp: symbolic link to `gimp-2.2'
Owen
2005-04-08 13:08:36 UTC (about 20 years ago)
On Thu, 7 Apr 2005 16:15:11 +0200 Rikard Johnels wrote:
Why cant i compile?
At a rough guess, your LD_LIBRARY PATH is probably /usr/lib
Set your LD_LIBRARY_PATH=/opt/lib:/usr/local/lib:/usr/lib
You better find out where your gimp-2.0pc file is and maybe amend that path as well PKG_CONFIG_PATH=/opt/lib/pkgconfig:/usr/local/lib/pkgconfig/:/usr/lib/pkgconfig/
HTH
Owen
