creating white text with transparent background
creating white text with transparent background Cortona0831 12 Dec 06:06
  creating white text with transparent background Alexandre Prokoudine via gimp-user-list 12 Dec 11:24
   creating white text with transparent background Cortona0831 07 Jan 21:24
  creating white text with transparent background Ofnuts 12 Dec 12:18
   creating white text with transparent background Cortona0831 07 Jan 21:25
2018-12-12 06:06:31 UTC (over 6 years ago)
Is there a resource, or a PDF, etc. that explains HOW TO create a new PNG document with only WHITE TEXT ON A TRANSPARENT BACKGROUND? Since the workspace screen is white, what do you need to do to see the text you're creating in white? That's all I'm trying to do. Appreciate any help. Thanks!
2018-12-12 11:24:29 UTC (over 6 years ago)
1. File > New...
2. Expand 'Advanced options'
3. Fill with: Transparency.
Alex
2018-12-12 12:18:03 UTC (over 6 years ago)
Just delete the default "Background" layer (Trashbin icon t the bottom of the Layers list) or make it invisible (eye icon next the layer preview).
2019-01-07 21:24:51 UTC (over 6 years ago)
1. File > New...
Alex
Thank you!
2019-01-07 21:25:16 UTC (over 6 years ago)
Thank you!
