entry point error message
hello, I originally installed gimp 2.10. But after finding out that
many of the youtube videos concern gimp 2.8 instead of 2.10 I down
loaded 2.8. When I try to open it it will not let me and says The
procedure entry point inflateValidate could not be located in the
dynamic link library C:Program Files\GIMP 2\bin\libpng 16-16.dll.
Can anyone help me please? Thanks
Anything to do with using a Windows TWAIN scanner?
see: https://gitlab.gnome.org/GNOME/gimp/issues/1383
If not give details of what you are doing.
Generally:
It could be that there are files left over from installing Gimp 2.10 followed by installing Gimp 2.8
Use Windows uninstall menu to uninstall Gimp (whatever version showing - Gimp 2.8)
If there is C:\Program Files\GIMP 2\ folder remaining delete it.
Make sure you are using the last Windows installer from gimp.org
https://download.gimp.org/mirror/pub/gimp/v2.8/windows/gimp-2.8.22-setup.exe
Reinstall Gimp 2.8 again using that version.
