Removing White Spots From Photo
Removing White Spots From Photo lkl316 03 Jul 13:21
  Removing White Spots From Photo Andrew 04 Jul 18:16
   Removing White Spots From Photo lkl316 06 Jul 15:08
    Removing White Spots From Photo programmer_ceds 06 Jul 15:49
     Removing White Spots From Photo programmer_ceds 07 Jul 13:51
    Removing White Spots From Photo Andrew 06 Jul 16:17
2018-07-03 13:21:03 UTC (almost 7 years ago)
What is the best tool to remove white spots from old photo?
Andrew
2018-07-04 18:16:16 UTC (almost 7 years ago)
I use the clone tool.
2018-07-06 15:08:13 UTC (almost 7 years ago)
It' not clear to me how to change the radius of the clone tool, and how to turn it off after usage..
2018-07-06 15:49:07 UTC (almost 7 years ago)
You can change the size in the tool dialog or (on the locale that I use at any rate) the [ and keys decrease and increase the size respectively.
The clone tool will stay selected until you select a different tool
Andrew
2018-07-06 16:17:55 UTC (almost 7 years ago)
Windows -> Dockable Dialogues -> Tool options
and how to turn
Like the other tools... Select a different one
2018-07-07 13:51:06 UTC (almost 7 years ago)
Should have read:
You can change the size in the tool dialog or (on the locale that I use at any rate) the [ and ] keys decrease and increase the size respectively.
