PNG and transparency
PNG and transparency Johannes Reese 16 Mar 09:08
  PNG and transparency Øyvind Kolås 16 Mar 09:31
Johannes Reese
2005-03-16 09:08:35 UTC (about 20 years ago)
Hi all,
what determines if pressing the wipe-out button or pressing CTRL-x extinguishes to either the background color or to transparency? I thought the type of file would. But some png-files I opened behaved so that CTRL-x of a selected area makes the deleted stuff transparent (which I want), while with others all I can reach is substituting the selected area by the background color. How can I force those files to delete to transparency?
Johannes
Øyvind Kolås
2005-03-16 09:31:56 UTC (about 20 years ago)
On Wed, 16 Mar 2005 09:08:35 +0100, Johannes Reese wrote: while with
You must make sure the image is in RGB mode (the titlebar should indicate this). If it's not the menu item "Image/Mode/RGB" . Next you must make sure that the background layer has an alpha channel, if it hasn't you can add one with the menu item "Layer/Transparency/Add alpha channel".
/pippin
