compile help
compile help John Griessen 18 Apr 09:31
  compile help Michael Schumacher 18 Apr 10:28
   compile help John Griessen 18 Apr 10:37
   compile help John Griessen 18 Apr 16:26
John Griessen
2018-04-18 09:31:53 UTC (about 7 years ago)
compile help
what does it mean when you get this:
gimp: symbol lookup error: gimp: undefined symbol: gimp_convert_dither_type_compat_get_type
attempting to run the install, and the GUI comes up when running in the build dir:
./app/gimp-2.10
To build, I ran this configure command:
./configure --prefix=/usr/local --datarootdir=/usr/local/share
2018-04-18 10:28:55 UTC (about 7 years ago)
compile help
You should use a different prefix.
John Griessen
2018-04-18 10:37:05 UTC (about 7 years ago)
compile help
such as --prefix=/usr/local/gimp-2.10 ?
Thanks,
John Griessen
industromatic.com  Austin TX  building lab gear for biologists
John Griessen
2018-04-18 16:26:51 UTC (about 7 years ago)
compile help
./configure --prefix=/usr/local/gimp gets me a good GUI from any working dir.
How do I get rid of this message:
Missing fast-path babl conversion detected, Implementing missing babl fast paths accelerates GEGL, GIMP and other software using babl, warnings are printed on first occurance of formats used where a conversion has to be synthesized programmatically by babl based on format description
Configure passed saying babl installed...
https://gist.github.com/jgriessen/5929128a744654944753d5f1e88d5abe
checking for recommended xgettext version (>= 0.19)... yes checking for iso-codes... yes
checking for BABL... yes
checking for GEGL... yes
checking for ATK... yes
checking for pkg-config... (cached) /usr/bin/pkg-config
