What have I installed?
What have I installed? Peter Wadeson 20 Sep 09:45
  What have I installed? Patrick Shanahan 23 Sep 11:15
  What have I installed? Ofnuts 24 Sep 10:10
   What have I installed? Ross Martinek 24 Sep 17:12
Peter Wadeson
2017-09-20 09:45:01 UTC (about 8 years ago)
I have installed version 2.8.22 of GIMP on an iMac running MacOS Sierra.
The GIMP web site suggests that either 32 or 64 bit software will be installed depending on the MacOS of the machine.
Is there any way of finding out which version has actually been installed? Either 32 or 64 bit.
Many thanks
Peter Wadeson
Patrick Shanahan
2017-09-23 11:15:45 UTC (about 8 years ago)
* Peter Wadeson [09-23-17 05:39]:
Many thanks
is your imac 32 or 64 bit?
if you really do not know, what difference does it make?
Photos: http://wahoo.no-ip.org/piwigo		    paka @ IRCnet freenode
2017-09-24 10:10:44 UTC (about 8 years ago)
Some system utility can tell you the "bitness" of the Gimp executable. On Linux this would be the "file" command:
>file /usr/bin/gimp-2.8 /usr/bin/gimp-2.8: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.6.32,
BuildID[sha1]=0d7d1efafc28d041a904a773cf3cb9e1b2532743, stripped
"file" is part of Unix since 1973 so it possibly exists on OSX.
Ross Martinek
2017-09-24 17:12:46 UTC (about 8 years ago)
Look at the name of the .dmg file you downloaded. It will tell you what version: e.g., gimp-2.8.20-x86_64.dmg. The last two digits after the underscore and before the extension are the bit version.
Ross
/usr/bin/gimp-2.8: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.6.32, BuildID[sha1]=0d7d1efafc28d041a904a773cf3cb9e1b2532743, stripped
"file" is part of Unix since 1973 so it possibly exists on OSX. _______________________________________________ gimp-user-list mailing list
