no pressure sensitivity on surface pro 4
no pressure sensitivity on surface pro 4 jason kolano 19 Sep 01:46
  no pressure sensitivity on surface pro 4 Jehan Pagès 19 Sep 18:35
jason kolano
2017-09-19 01:46:25 UTC (over 7 years ago)
Hi there. I have no pressure sensitivity when digital painting in gimp on my surface pro 4. I went over it for days with their tech support until finally they said it has to be a problem with the gimp and to get a hold of you guys. I think this is a super important issue as pressure sensitivity is the whole reason digital painting is fun. Thanks!
Jason
Sent from Mail for Windows 10
Jehan Pagès
2017-09-19 18:35:58 UTC (over 7 years ago)
I assume you use it with the default Windows OS? GTK+ (hence GIMP) supports tablet features (such as pressure sensitivity) through Wintab drivers. After a small search, it appears that there are Wintab drivers for the Surface Pro 4 but they are optional (hence not installed by default, I guess). This page on Microsoft website has the drivers for download: https://www.microsoft.com/en-us/download/details.aspx?id=49498 I would suggest to try and install these, then try GIMP again. Regards,
Jehan
Thanks!
Jason
ZeMarmot open animation film
http://film.zemarmot.net
