After re-installation no print option
After re-installation no print option Peter J. de Vrijer 24 Jan 12:25
  After re-installation no print option Carol Spears 24 Jan 16:16
Peter J. de Vrijer
2005-01-24 12:25:50 UTC (about 20 years ago)
After re-installing gimp v 2.0.4 the print option is gone (it was working before).
I have also installed gimp-print and foomatic and cups (which prints nicely).
So what am I doing wrong?
Greetings Peter.
Carol Spears
2005-01-24 16:16:35 UTC (about 20 years ago)
it would be good to know more about your installation.
right now, i can tell only that you are using linux.
if you are using a binary provided by a distribution, this might be a known problem or perhaps your distribution has a more current version available.
if you are building your own from the tarball, the suggestion would be to get a more current version.
