resizing canvas question
resizing canvas question carla 18 Mar 16:07
  resizing canvas question Pat David 18 Mar 19:41
  resizing canvas question Pat David 18 Mar 21:40
  resizing canvas question rich2005 19 Mar 09:37
carla
2017-03-18 16:07:08 UTC (about 8 years ago)
I'm getting so frustrated with the lack of intuitive functioning of this program I'm just about ready to go back and pay for photoshop. Arghhh.... I have made a change in an image rotating part of it so that it now extends above the edge of the canvas. Resizing the canvas to layers does nothing. I had similar problems extending the canvas when I added an image from another file but nothing worked to fix that problem either. It was all so easy in photoshop- why is this so difficult????
-- View this message in context: http://gimp.1065349.n5.nabble.com/resizing-canvas-question-tp50350.html Sent from the Users mailing list archive at Nabble.com.
Pat David
2017-03-18 19:41:30 UTC (about 8 years ago)
This is difficult because it's not Ps, and I get the impression you haven't had a chance to read through he manual yet.
Perhaps you could upload an .xcf file that you're having problems with for us to see? https://filebin.net the come back here and give us the link. On Sat, Mar 18, 2017 at 12:31 PM carla wrote:
http://gimp.1065349.n5.nabble.com/resizing-canvas-question-tp50350.html Sent from the Users mailing list archive at Nabble.com. _______________________________________________ gimp-user-list mailing list
https://patdavid.net
GPG: 66D1 7CA6 8088 4874 946D  18BD 67C7 6219 89E9 57AC
Pat David
2017-03-18 21:40:21 UTC (about 8 years ago)
How _exactly_ did you try to resize the canvas? What menu item did you choose to do this?
2017-03-19 09:37:16 UTC (about 8 years ago)
file but nothing worked to fix that problem either. --snip--
Probably using the wrong tool or do not understand how the tool works or expecting click-n-wish to work
Without greater details of the image you are using, all a bit of a guess but this is a demo of
1. Image menu -> Fit Canvas To Layers
2. Image menu -> Resize Canvas
Either probably do the job, only 1 minute 30 seconds so no great epic.
https://youtu.be/2fgJX7msSEc
