16-bit: Photivo and Gimp
9 of 9 messages available
16-bit: Photivo and Gimp oneaty 16 Mar 02:11
  16-bit: Photivo and Gimp rich2005 16 Mar 09:11
   16-bit: Photivo and Gimp oneaty 16 Mar 10:17
    16-bit: Photivo and Gimp rich2005 16 Mar 10:46
    16-bit: Photivo and Gimp oneaty 17 Mar 11:24
     16-bit: Photivo and Gimp oneaty 17 Mar 11:28
      16-bit: Photivo and Gimp Pat David 17 Mar 20:27
       16-bit: Photivo and Gimp oneaty 17 Mar 23:39
        16-bit: Photivo and Gimp oneaty 18 Mar 12:27
2017-03-16 02:11:00 UTC (about 8 years ago)
I have Gimp 2.8.16 (Ubuntu 16.04) and I'm trying to edit a 16-bit image the following way:
1 - Import DNG file into Photivo; 2 - Make adjustments
3 - Open the resulting image in Gimp 4 - Save tiff file
When I edit the Gimp resulting tif file with mediainfo, it says it is a 8-bit image.
How can I edit and save 16-bit images.
2017-03-16 09:11:17 UTC (about 8 years ago)
Gimp 2.8.x is 8 bit only. Wait for Gimp 2.10 or use the development version Gimp 2.9.x
For 'buntu and derivatives this is easily installed using a PPA. see
https://launchpad.net/~otto-kesselgulasch/+archive/ubuntu/gimp-edge
Updates frequently but is quite stable and usable. This will replace the existing Gimp 2.8.16 installation.
It is possible to run both if the 2.9 is a 'portable' application. There are a few around.
Search for appimage. There is a 2.9.3 here that should work in most linux https://bintray.com/probono/AppImages/ and https://bintray.com/probono/AppImages/GIMP
I keep an up-to-date 2.9.5 assembled in 'buntu 16.04 that should work in your installation. Nothing guaranteed though. see
http://www.gimp-forum.net/Thread-Portable-Gimp-2-9-5-for-linux
Used to be a fan of photivo, but development seems to have stalled in 2015. The gimp plugin stopped working for me. There are other tools, RawTherapapee for example. If you have photivo from the dhor/myway PPA it is there for installation.
example in kubuntu 16.04 http://i.imgur.com/tbPx1QP.jpg (but using nUFRaW)
2017-03-16 10:17:10 UTC (about 8 years ago)
Wow, great information, thanks!
As for Photivo Gimp plugin you referred to, is it the code that allows the "Send image to external editor" function?
I'll give a try with RawTherapee, but Photivo, gave me the best results out of the box, besides offering a ton of options if I want to go further in post production...
Once more, thanks for the great information
2017-03-16 10:46:01 UTC (about 8 years ago)
It was the pt..something plugin in Photivio that gave problems, Quite a while since I last used it.
But stick with Photivo, save as a 16 bit tiff, then open with Gimp 2.9.5
For RawTherapee, use this PPA to get the latest version 5
https://launchpad.net/~dhor/+archive/ubuntu/myway It is worth enabling anyway, lots of good stuff there.
RawTherapee will send to Gimp but for a portable Gimp you will need to put the Gimp location in the RawTherapee preferences. example: http://i.imgur.com/yG4BjSY.jpg
Truthfully, a bit over the top for me and my requirements. The place for information is https://discuss.pixls.us/
2017-03-17 11:24:24 UTC (about 8 years ago)
I tried RawTherapee and, together with the new 16-bit Gimp, I can say I found an excellent replacement for PS.
Just as an example, I could manage to develop the raw image below the way I would do with PS. I didn't loose much time in the tonal settings, but I was curious to see if I could enhance the image regarding sharpness and noise. I think I could.
I did the basics in RawTherapee then opened it in Gimp, where I applied the smart sharpening method proposed by this fellow that I don't know the name (http://gimpguru.org/Tutorials/SmartSharpening2/).
Since I'm shooting with an old and humble Canon Powershot A3100 running CHDK, from where I'm able to get raw images, I can now say that I'm 100% GNU,
http://imgur.com/a/o3o4r
2017-03-17 11:28:27 UTC (about 8 years ago)
EDIT: The picture I shoot is no master piece, but shooting in raw and having a good raw developer allowed me to recover details from the big white clouds, something that on the original jpg shows as blown up white.
Pat David
2017-03-17 20:27:09 UTC (about 8 years ago)
For the best results you might want to consider sharpening in the raw processor as well. :)
-- oneaty (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
https://patdavid.net
GPG: 66D1 7CA6 8088 4874 946D  18BD 67C7 6219 89E9 57AC
2017-03-17 23:39:05 UTC (about 8 years ago)
Why does it give best results?
2017-03-18 12:27:52 UTC (about 8 years ago)
I think the answer os in chain83 post here https://www.reddit.com/r/postprocessing/comments/38vdao/how_does_everyone_sharpen_their_photos/
According to that, you're suggesting to also apply input sharpening
Thanks for the tip anyway.
