Batch resize issues.
Batch resize issues. lupussonic 04 Mar 15:13
  Batch resize issues. Ofnuts 06 Mar 17:00
2017-03-04 15:13:41 UTC (about 8 years ago)
Hi, just got GIMP 2.8.20...
downloaded 'Daves batch Resizer' and put it in the plugin folder.
Using this page...
http://www.makeuseof.com/tag/use-gimp-to-batch-edit-your-images-windows-specific-instructions/
it should show an xtns dropdown menu, but mine does not have one.
Any help much appreciated. thank you. Looking forward to getting started.
2017-03-06 17:00:45 UTC (about 8 years ago)
Using this page...
Search in "Filters". Now this page was written in 2008 or so, and things have evolved a bit. You can use thr BIMP plugin instead.
Other software (XnView, IrfanView...) will also have batch resize capabilities. And you can use also Imagemagick.
