Changing color scheme across all layers in a gif
7 of 7 messages available
Changing color scheme across all layers in a gif trevard 01 Feb 23:39
  Changing color scheme across all layers in a gif Ofnuts 02 Feb 14:25
   Changing color scheme across all layers in a gif trevard 02 Feb 15:05
    Changing color scheme across all layers in a gif Ofnuts 02 Feb 18:03
     Changing color scheme across all layers in a gif trevard 02 Feb 18:39
      Changing color scheme across all layers in a gif rich2005 02 Feb 21:05
      Changing color scheme across all layers in a gif Ofnuts 03 Feb 11:34
2017-02-01 23:39:43 UTC (about 8 years ago)
I have a gif that is a cool (blue) color scheme and I need the same exact gif but warm (red) colors.
Is there a way to convert the color scheme across all layers from cool to warm?
I have included the gif in question and an image that reflects the color scheme I am hoping to convert it to.
-Thanks
2017-02-02 14:25:24 UTC (about 8 years ago)
Two ways:
Simple:
Image>Mode RGB Colors>Rotate colors
Hardcore:
Windows>Dockable dialogs>Color map Edit the color values in the color map
-Thanks
Attachments: * http://www.gimpusers.com/system/attachments/449/original/arrow_l_l_off.gif * http://www.gimpusers.com/system/attachments/450/original/arrow_l_l_off-Hot.png
2017-02-02 15:05:50 UTC (about 8 years ago)
I appreciate the reply but I'm not even getting close with either of those methods.
-Thanks
2017-02-02 18:03:48 UTC (about 8 years ago)
-Thanks
Hmmm. Several layers... then only the colormap method would work. Now, "cold" and "warm" have no meaning in Gimp. What has a meaning is "this R,G,B triplet becomes this R,G,B one".
If you post a frame of your GIF, we could better understand what you want to do.
2017-02-02 18:39:17 UTC (about 8 years ago)
Sure thing I obviously have near no experience with GIMP and I truly do appreciate your efforts to help me. I'm not sure what exactly you mean by "frame" but I included a screen shot and the GIF itself hope that helps.
2017-02-02 21:05:18 UTC (about 8 years ago)
A frame is a layer, it even shows that in your screenshot.
The color-map is too complicated to easily edit so change the gif color mode to RGB Image -> Mode -> RGB
The gif is optimized so un optimize it Filters -> Animation -> Unoptimize
One way (there will be others) is make a color mask of the arrow (incl border pixels) in red.
That is then merged as an overlay with layer mode = color and reduced opacity (75%) for each of the 21 layers in turn.
Very tedious but there are plugins to help. Ofnuts has one 'interleave-layers' see:
http://sourceforge.net/projects/gimp-tools/files/scripts/
about 30 entries down
In practice looks like the attached screenshot
then the result has to be re-optimized and exported as an animated gif.
To be honest, not that easy for a beginner.
2017-02-03 11:34:13 UTC (about 8 years ago)
Attachments: * http://www.gimpusers.com/system/attachments/451/original/arrow.PNG * http://www.gimpusers.com/system/attachments/452/original/arrow_r_r_on.gif
A layer in the GImp image becomes a "frame" in the GIF animation.
So, there could be a fast an easy solution:
- Get the interleave-layers script from here: http://gimp-tools.sourceforge.net/animationtools.shtml
- Add a layer to your image, fill it with required hue, then make it invisible
- Using Interleave-layers in "title" mode, interleave/merge it using the "Hue" blend mode
For more control:
- Instead of filling the whole layer, fill just the shape of the arrow, leave the rest transparent
- Using Interleave-layers in "title" mode, interleave/merge it using the "Color" blend mode
The script just uses the standard blend mode, so before calling the script you can make a test by changing the blend mode of the added layer, and adjusting the color for the required results.
