Netscape question
Netscape question Rick Strong 15 Jan 23:08
  Netscape question Rick Strong 16 Jan 05:22
  Netscape question Shlomi Fish 16 Jan 10:51
   Netscape question Rick Strong 16 Jan 16:24
Rick Strong
2017-01-15 23:08:32 UTC (over 8 years ago)
Netscape question
I know this is the GIMP list, but if anyone knows who I can contact to ask a simple question of Netscape 0.92.0 r15299, like, “How do I (can I) add a keyboard shortcut without having to edit an xml file?”, I would be most appreciative. Win7 Pro 64bit, SP 1. They can reply to me directly.
Thanks, Rick S.
Rick Strong
2017-01-16 05:22:41 UTC (over 8 years ago)
Netscape question
I found it. It's an undocumented feature.
1. Edit > Preferences > Interface > Keyboard shortcuts. 2. Find the menu item you want to add/change the keyboard shortcut for. 3. Under the "Shortcut" column, click on the existing key or key combination (key+modifier).
4. A blue bar with "New Accelerator ..." will appear. 5. Type your new key or key combo. In a few second the blue bar should disappear.
6. The new key or key combo should now be visible. 7. Exit the dialogue.
8. The new keyboard shortcut is immediately active.
Be careful what you type because it appears that the only way to erase a mistake is to push the Reset button. This wipes out all your customized key codes and returns you to the keyboard shortcut set named at the top of the dialogue.
Cheers,
Rick S.
-----Original Message----- From: Rick Strong
Sent: Sunday, January 15, 2017 6:08 PM To: GIMP User List
Subject: [Gimp-user] Netscape question
Thanks, Rick S.
Shlomi Fish
2017-01-16 10:51:22 UTC (over 8 years ago)
Netscape question
Hi Rick,
First of all note that you're probably referring to Inkscape (see https://en.wikipedia.org/wiki/Inkscape ) rather than "Netscape". Otherwise Inkscape have their own mailing lists and forums, see:
* https://inkscape.org/en/community/mailing-lists/
* https://inkscape.org/en/community/discussion/
You can ask questions there.
Shlomi Fish
Thanks,
Rick S.
Shlomi Fish       http://www.shlomifish.org/
http://shlomifishswiki.branchable.com/Encourage_criticism_and_try_to_get_offended/
Chuck Norris refactors 10 million lines of Perl code before lunch.
    — http://www.shlomifish.org/humour/bits/facts/Chuck-Norris/
Rick Strong
2017-01-16 16:24:29 UTC (over 8 years ago)
Netscape question
Yes, of course it was Inkscape. My bad typing. Thanks for the links.
Rick S.
-----Original Message----- From: Shlomi Fish
Sent: Monday, January 16, 2017 5:51 AM To: Rick Strong
Cc: GIMP User List
Subject: Re: [Gimp-user] Netscape question
Hi Rick,
Shlomi Fish
Thanks,
Rick S.
