GIMP 2.9 Nightly - Plugin Errors
GIMP 2.9 Nightly - Plugin Errors FierySwordswoman 31 Oct 05:11
  GIMP 2.9 Nightly - Plugin Errors FierySwordswoman 31 Oct 05:16
FierySwordswoman
2016-10-31 05:11:45 UTC (over 8 years ago)
I normally use Partha's GIMP 2.9 builds, but I decided to try the Nightly builds of 2.9 for a change. Long story short, no 3rd party scripts load. All of my older scripts & the Resynthesizer scripts return "Failed to execute child process (No such file or directory)" to the console when GIMP tries to load them. My newer scripts oddly return
"(Exec format error)"
instead, as if they're not proper plugins. Finally, the Resynthesizer .exe plugin loads fine. I understand the Partha builds are a bit modified, but surely loading some simply Python plugins shouldn't be a problem, right?
FierySwordswoman
2016-10-31 05:16:20 UTC (over 8 years ago)
Actually, I don't think it has Python in it. That's probably the issue. Probably no helping that.
