Tiff-library not found for gimp 2.2
10 of 10 messages available
Tiff-library not found for gimp 2.2 Jogchum Reitsma 26 Nov 14:57
  Tiff-library not found for gimp 2.2 Sven Neumann 26 Nov 16:45
   Tiff-library not found for gimp 2.2 Jogchum Reitsma 26 Nov 19:09
    Tiff-library not found for gimp 2.2 Jeff Trefftzs 26 Nov 20:42
    Tiff-library not found for gimp 2.2 Sven Neumann 26 Nov 20:45
     Tiff-library not found for gimp 2.2 Jogchum Reitsma 26 Nov 22:54
    Tiff-library not found for gimp 2.2 Carol Spears 26 Nov 21:45
     Tiff-library not found for gimp 2.2 Jogchum Reitsma 27 Nov 12:26
      Tiff-library not found for gimp 2.2 Carol Spears 27 Nov 17:46
    Tiff-library not found for gimp 2.2 Manish Singh 28 Nov 01:24
Jogchum Reitsma
2004-11-26 14:57:21 UTC (over 20 years ago)
I did a ./configure on the gimp-2.2 source (not the CVS-line), and it complained about not finding the TIFF-library. So I downloaded that (v. 3.70), compiled and installed it (the libraries install in /usr/local/lib) and ran ldconfig.
Still ./configure doesn't find it.
What am I doing wrong?
Thanks,
Jogchum Reitsma
2004-11-26 16:45:50 UTC (over 20 years ago)
Jogchum Reitsma writes:
You forgot to read INSTALL, in particular the section that is titled "When ./configure fails on plug-ins".
Jogchum Reitsma
2004-11-26 19:09:40 UTC (over 20 years ago)
Thanks for your quick reply.
Frankly, I did read INSTALL, and also that section, but didn't think the solution offered there would bring me luck.
But after your reply I did
export LDFLAGS="-L/usr/local/lib"
before running configure.
This is what configure says:
checking for TIFFReadScanline in -ltiff... no checking for TIFFWriteScanline in -ltiff... no checking for TIFFFlushData in -ltiff34... no configure: WARNING: *** TIFF plug-in will not be built (TIFF library not found) ***
configure: error:
*** Checks for TIFF libary failed. You can build without it by passing *** --without-libtiff to configure but you won't be able to use TIFFs then.
There are no more references to libtiff in the output from configure, as far as I can see.
Maybe I installed the wrong version of libtiff? Mine is 3.7.0: /usr/local/lib reads among other:
lrwxrwxrwx 1 root root 13 2004-11-26 14:46 libtiff -> libtiff.3.7.0* lrwxrwxrwx 1 root root 13 2004-11-26 14:46 libtiff.3 -> libtiff.3.7.0* -rwxr-xr-x 1 root root 700919 2004-11-26 14:46 libtiff.3.7.0* -rw-r--r-- 1 root root 981630 2004-11-26 14:46 libtiff.a -rwxr-xr-x 1 root root 783 2004-11-26 14:46 libtiff.la*
I don't need the tiff-library myself, so I could give --without-libtiff to configure. But since testing is my object, it would be nice to have it included.
Thanks, Jogchum
Jeff Trefftzs
2004-11-26 20:42:55 UTC (over 20 years ago)
configure: error:
Do you have /usr/local/lib in your /etc/ld.so.conf file? Make sure it's there, and run ldconfig again and see what happens.
HTH,
2004-11-26 20:45:27 UTC (over 20 years ago)
configure: error:
Does your linker look into /usr/local/lib at all? If you install libraries there, you either have it in /etc/ld.so.conf and updated your linker cache or you set LD_LIBRARY_PATH, didn't you?
Carol Spears
2004-11-26 21:45:21 UTC (over 20 years ago)
there is a script that sets many of these things for you so that the build will go smoothly.
http://www.gimp.org/source/howtos/gimpenv
type "source gimpenv" with the term you will use to build gimp and other /usr/local/ things and many of the details are taken care of.
i use my personal copy to set the CVSROOT as well.
Jogchum Reitsma
2004-11-26 22:54:08 UTC (over 20 years ago)
Sorry, just after I sent my previous posting I realized I should have added that I indeed checked /etc/ld.so.conf. Indeed /usr/local/lib is in there, and only after checking this I ran ldconfig.
I'll try Carol's hint tomorrow - going to bed now.
thanks again, greetings, Jogchum
configure: error:
Jogchum Reitsma
2004-11-27 12:26:16 UTC (over 20 years ago)
Carol,
Thanks for your info. But after following your advice, the result is the same... By the way, since my distro - SuSE 9.2 - installs gimp-2.0 somewhere in /opt/gnome, I take the standard /usr/local for installing gimp 2.2.
kind greetings, Jogchum
Carol Spears
2004-11-27 17:46:23 UTC (over 20 years ago)
that means you do not have to edit the script. i am sorry it did not help you with your problems, it probably helped you with other problems unless you have these environment variables set somewhere else (.bashrc or .bash_profile is one controversial option).
hopefully someone else will figure out the real solution.
Manish Singh
2004-11-28 01:24:07 UTC (over 20 years ago)
configure: error:
Check config.log for details for why the check failed.
-Yosh
