Question About Gif Animation
Question About Gif Animation Silicon_Chipmunk 02 Oct 23:50
  Question About Gif Animation achbarrr@gmail.com 03 Oct 10:01
  Question About Gif Animation Jan Kandziora 03 Oct 11:49
   Question About Gif Animation Silicon_Chipmunk 05 Oct 19:04
2016-10-02 23:50:58 UTC (over 8 years ago)
Hi, I hope someone can help.
Sorry if this has already been asked, I couldn't find anything similar in the forums but might have missed something.
Is it possible to make a gif where two different things move at two different speeds? For example if I was animating a dragon, is there a way to make its wings to move at one speed (looped) while its eyes blink at a faster speed?
I keep wanting to make two Layer Groups so I can animate things separately, but know this won't work since Gimp can't animate layers in Groups. Any advice would be greatly appreciated.
achbarrr@gmail.com
2016-10-03 10:01:50 UTC (over 8 years ago)
All you need is in adobe flash or you can try some like that called SYNFIG. this is best way to make great anination if you know
Silicon_Chipmunk (via www.gimpusers.com/forums)
Jan Kandziora
2016-10-03 11:49:05 UTC (over 8 years ago)
Am 03.10.2016 um 01:50 schrieb Silicon_Chipmunk:
There is only one frame rate in animated GIFs. When you need different speeds for different parts of an animation, you need to double/triple and so on the "slow" frames, while animating the fast parts in it.
Basically, do this:
frame 0: wings up - eyes open frame 1: wings up - eyes closed
frame 2: wings down - eyes open
frame 3: wings down - eyes closed
loop
Again, I recommend ImageMagick to do that duplication and animation work for you, see this example:
http://www.imagemagick.org/Usage/anim_mods/#composite
It first creates a coalesced_k.gif (a full frame/non-optimizied gif), then makes a shadows_k.gif from the original one -only for demonstration purposes, could be any "background" animation, e.g. your winged dragon-, then compose that background animation with the original coalesced_k.gif to compose_shadow.gif.
(gif_anim_montage is just a script which created the strip at the bottom of the tutorial step)
You are done!
Okay, if you want to do that wing flapping at a slower speed, you first had to double each frame within the gif. That's a bit trickier:
http://www.imagemagick.org/discourse-server/viewtopic.php?p=50325#p41868
Hope that helps.
Kind regards
Jan
2016-10-05 19:04:27 UTC (over 8 years ago)
Am 03.10.2016 um 01:50 schrieb Silicon_Chipmunk: There is only one frame rate in animated GIFs. When you need different speeds for different parts of an animation, you need to double/triple and so on the "slow" frames, while animating the fast parts in it. Basically, do this:
loop
You are done!
Hope that helps.
Kind regards
Jan
Thank you, Jan. :)
