Smart Separate Sharpen
Smart Separate Sharpen Alan Huntley 06 Aug 23:33
  Smart Separate Sharpen Steve Kinney 07 Aug 02:45
   Smart Separate Sharpen Akkana Peck 07 Aug 16:13
   Smart Separate Sharpen Alan Huntley 07 Aug 16:44
Alan Huntley
2016-08-06 23:33:38 UTC (over 8 years ago)
Hello All,
Just downloaded and installed this script from the GIMP Plugin Registry, but I can't seem to find it on any menu. Can anybody tell me where I should find it listed?
Thank you.
Kind regards, Alan
2016-08-07 02:45:01 UTC (over 8 years ago)
On 08/06/2016 07:33 PM, Alan Huntley wrote:
Hello All,
In the past I have found the menu locations of scripts by opening them up with a text editor and hunting it down there.
Akkana Peck
2016-08-07 16:13:58 UTC (over 8 years ago)
Steve Kinney writes:
Or use Help->Plug-in Browser, assuming you can guess something about what name the plug-in uses in the menus.
...Akkana
Alan Huntley
2016-08-07 16:44:21 UTC (over 8 years ago)
Steve,
Thanks for the help. Per your suggestion, I found out that the script is labeled as "Eg" on the Filters menu.
Alan
Hello All,
should
find it listed?
