Basic Color Management
Basic Color Management Mike Brennan 20 Jan 20:54
  Basic Color Management Gez 03 Feb 04:14
  Basic Color Management Kevin Brubeck Unhammer 11 Feb 15:37
Mike Brennan
2016-01-20 20:54:36 UTC (over 9 years ago)
GIMP 2.8.14 Windows 7 64
In Preferences -> Color Management I've selected "Mode of operation" = "Color managed display"
There's a checkbox: "Try to use the system monitor profile" that I'm unclear about.
I've calibrated/profiled my display with ColorMunki hardware. My understanding (wrong?) is that ColorMunki installed an appropriate profile for my display on the system, and that all output from ANY application to the display goes through an OS driver that uses that profile. If that is so, my assumption is that GIMP will "use" the correct display profile implicitly, without needing to be told to do so.
I do not understand whether checking "Try to use the system monitor profile" is unnecessary, redundant, or even harmful.
-Mike
Gez
2016-02-03 04:14:12 UTC (about 9 years ago)
As far as I can tell from my linux install, marking that checkbox overrides whatever display profile you selected and uses the profile installed in your current user.
I'm not sure if other platforms behave the same, but that's how it works on Linux.
Having selected a display profile from disk doesn't result in a redundand or harmful adjustment, as it's just ignored when that checbox is set.
I guess it's easy to check if that's working in your system: Just set the display profile to none, and mark the checkbox, then flip between "color managed display" and "no color managment". If there is a change, then your system color profile is working. You should get the same change turn on and off the checkbox (and your monitor display is set to none).
If you set manually the same display profile your system use, turning on and off the checbox shouldn't make any difference.
Gez.
2016-02-11 15:37:30 UTC (about 9 years ago)
"Mike Brennan" čálii:
When you profile your display you get a two-part result:
- a vcgt/LUT part that does white point correction, applied system-wide on login (it's often noticable when this is applied, e.g. with slightly colder or warmer colours all-round)
- a gamma/hue/saturation part that has to be applied by individual colour-managed programs
On Linux, if you have the right setup, programs can query the system for what file contains the gamma/hue/saturation part – that's the part that's applied by the "Try to use the system monitor profile" checkbox. So this should work in e.g. GNOME or KDE if you've selected your profile in your system colour management settings, but in desktops like XFCE you have to run a separate program, or select the profile manually from GIMP settings.
Caveat: I have no formal training in this, please read what the experts say instead:
https://encrypted.pcode.nl/blog/2013/11/24/display-color-profiling-on-linux/
