Help with GIMP Gif
Help with GIMP Gif pickupthestix16 21 Dec 19:43
2015-12-21 19:43:40 UTC (over 9 years ago)
Help with GIMP Gif
Hello All!
This is my first post and I'm a bit familiar with GIMP but am still kind of a newbie to the program. I particularly got it so that I could create my own signature for a forum that I participate on regularly.
I recently hit a road block that I can't seem to get around and I'm not sure if it's possible at all. I wanted to make an animated Gif image and I wanted the original gif to be transparent. I didn't know any other way to do this, so I simply separated all 54 frames and edited each photo myself, and then re-formatted them back into a gif. I then opened as layers each of the frames.
I used the "Lighten Only" effect on the rest of the images on the signature, so I wanted to keep the gif that way too. This required me to go through each of the 54 frames and select "Lighten Only". At first, I ran into this problem http://imgur.com/l5fiKq7. Even though each frame said "replace", it didn't seem to actually replace the previous frame.
Then I downloaded an animation script called "Animastack". I put [bg] on the background frame and [fg] on the foreground frame and then "processed animastack tags" and it grouped together all frames with the foreground and background so I had 54 separate groups. When I did the "playback" though, it worked! IT FINALLY WORKED! i was so happy; I had spent so long trying to get it to work.
Then I tried to export the file as a gif and ran into the "indexed or grayscale" issue. Is there ANY WAY to export this without changing the colors? Anything other than "gif" that I could export to that would have a similar effect?
Thank you for reading!! I appreciate any feedback/suggestions.
