HEX to Pantone Color Conversion
HEX to Pantone Color Conversion Robert & Betty Lustila 25 Nov 17:45
  HEX to Pantone Color Conversion Chris Mohler 25 Nov 22:42
   HEX to Pantone Color Conversion Steve Kinney 25 Nov 23:27
  HEX to Pantone Color Conversion Kevin Cozens 26 Nov 00:33
2015-11-25 17:45:30 UTC (over 9 years ago)
Good day, I'm looking to find a way to convert HTML 3e479a to its corresponding Pantone Color Code - Is there any way to do this? Thanks
Betty Lustila
Chris Mohler
2015-11-25 22:42:21 UTC (over 9 years ago)
I know of no reliable method (aside from having a swatch book and using the mark-one eyeball). That being said, try this: http://rgb.to/hex/3e479a
Or if you search the web for "HEX to Pantone", you will see some other tools pop up.
Also, (I think) Pantone used to have a color lookup on their own site. But I can't find it anymore.
But once again - I doubt any of these tools are super-reliable. This is from someone who used to mix Pantone ink colors.
HTH, Chris
2015-11-25 23:27:58 UTC (over 9 years ago)
True that. If the job in question requires only one Pantone color, a good approach might be to approximate it in RGB as best you are able, then tell the print shop what Pantone color that is supposed to be and leave it to them.
:o/
Steve
Kevin Cozens
2015-11-26 00:33:10 UTC (over 9 years ago)
On my website I have a file that has a Pantone-like palette for use with GIMP. I don't know how accurate the colours are to actual Pantone colours but you could take a look. The palette file can be seen at http://ve3syb.ca/software/gimp/extras.html
Cheers!
Kevin.
http://www.ve3syb.ca/           |"Nerds make the shiny things that distract
Owner of Elecraft K2 #2172      | the mouth-breathers, and that's why we're
                                 | powerful!"
#include  |             --Chris Hardwick
