Import/Open 16-bit RAW images?
Import/Open 16-bit RAW images? Yajie Sun 28 Oct 16:05
  Import/Open 16-bit RAW images? Jakub Friedl, adresa do konferenci 28 Oct 16:17
Yajie Sun
2004-10-28 16:05:27 UTC (over 20 years ago)
Is there a way to import/open a 16-bit RAW image in GIMP like ImageJ does?
Thank you very much,
YS
******************* IMPORTANT MESSAGE ******************************* Internet communications are not secure and therefore, Fischer Imaging does not accept legal responsibility for the contents of this message including any material attached to it. Any views or opinions presented are solely those of the author and do not necessarily represent those of Fischer Imaging, unless otherwise specifically stated. This email is confidential and may be legally privileged.
The copying, broadcasting, publishing or dissemination electronically or by any other means of the contents of this email or its attachments is prohibited, unless expressly authorized by the sender. It is the responsibility of the recipient to ensure that they have virus protection and no responsibility is accepted by Fischer Imaging for any loss or damage arising in any way from receipt or use thereof of this email or its attachments.
If received in error, you should not disclose or make use of or take any action in reliance upon this material but you should notify information@fischerimaging.com immediately. *********************************************************************
2004-10-28 16:17:02 UTC (over 20 years ago)
You can load it in the Gimp (using rawphoto plugin) but it will be converted to 8-bit image.
It is not possible to work with 16bit/channel images in the Gimp now. But you can try Cinepaint which can edit up to 32 bit per channel. It is derived from the Gimp but has a little old fashioned interface.
Jakub Friedl
