Factory settings/reset to defaults
Factory settings/reset to defaults Taisheena 28 Oct 02:24
  Factory settings/reset to defaults programmer_ceds 29 Oct 15:15
   Factory settings/reset to defaults programmer_ceds 29 Oct 15:17
   Factory settings/reset to defaults Taisheena 29 Oct 15:21
    Factory settings/reset to defaults Patrick Shanahan 30 Oct 13:31
2015-10-28 02:24:54 UTC (over 9 years ago)
I need to know how to set my GIMP 2.8.14 back to original settings. I tried: reset to defaults and nothing happened.
I have somehow messed up my text settings so that my letters are smashed up, and the size of the text box won't increase. I make a text box, but the text stays in about .25% of the box and starts wrapping.
Also, I closed my toolboxes and I can not figure out how to get them back to the way they were when I downloaded the program.
Thank you for taking the time to read, I apologize if this was already asked, I couldn't find it in the forums.
-tai
ps I have windows 8.1 64 bit
2015-10-29 15:15:43 UTC (over 9 years ago)
-tai
I'm not sure but I suspect if you terminate GIMP, take a copy of Users\\.gimp-2.8 (just in case things go wrong) and then delete the contents of that folder. Then when you restart GIMP (hopefully) it should recreate the contents of .gimp-2.8 using the default settings. If it all goes wrong termiate GIMP and restore the original contents of the folder.
Note that you would have to transfer and scripts, plug-ins, brushes etc that you had installed from the back-up folder to the newly created folder (when GIMP isn't running)
2015-10-29 15:17:34 UTC (over 9 years ago)
That should have read Users\user name\.gimp-2.8 (but I put less than and greater than signs around user name and this text didn't appear in the post)
2015-10-29 15:21:36 UTC (over 9 years ago)
I actually uninstalled the program, went in program files and deleted that whole folder - is there some other place that GIMP saves settings to?
Patrick Shanahan
2015-10-30 13:31:34 UTC (over 9 years ago)
* Taisheena [10-30-15 08:51]:
c:\users\\
look of any directory with a name containing "gimp" (remove quotes).
http://wahoo.no-ip.org        Photo Album: http://wahoo.no-ip.org/gallery2
