How to use bleed and cropping
10 of 10 messages available
How to use bleed and cropping nishu92 19 Oct 18:22
  How to use bleed and cropping nishu92 19 Oct 18:23
   How to use bleed and cropping Steve Kinney 20 Oct 16:41
    How to use bleed and cropping: BIG correction Steve Kinney 20 Oct 16:46
     How to use bleed and cropping: BIG correction heviiguy 21 Oct 10:39
      How to use bleed and cropping: BIG correction Sebastian McShane 21 Oct 10:53
       How to use bleed and cropping: BIG correction gimp-users.mbourne@spamgourmet.com 21 Oct 18:38
     Text display broken in 2.8.14 OS-X gimp? Douglas Ray 21 Oct 13:28
      Text display broken in 2.8.14 OS-X gimp? Liam R E Quin 21 Oct 20:26
       fixd Re: Text display broken in 2.8.14 OS-X gimp? Douglas Ray 21 Oct 22:13
2015-10-19 18:22:11 UTC (over 9 years ago)
I am trying to print some files for a game I made, but I have told for them to print I need to fix a few things which I have never done before such as: - my board needs to be 19.75" x 19.75" with a black boarder, currently it is 20" x 20" - My cards need be on 12" x 18" sheets. They need to be at least 1/2" from all edges. Crop lines need to be on the fronts. They should have 2-4mm bleed. All the backs need to be on one sheet, mirroring the fronts on another.
It is possible for someone to help me with this? I can send all my files.
2015-10-19 18:23:23 UTC (over 9 years ago)
I have been told: The easiest way is making the back ground all black. The art then should be 2mm inside the crop mark, so you'll have a black border around all our cards. How though?
2015-10-20 16:41:25 UTC (over 9 years ago)
How though?
I use Inkscape to prepare images for commercial printing: This is a Free desktop publishing program. Sorry about the "first get this other program and learn how to use it" answer, but if you do you will be glad you did.
Open Inkscape and start a new file, open File > Document Setup, and select double sided. Set the width & height, etc. as the job requires, to match the dimensions of the stock it will be printed on. Save the file early & often, of course.
Set up guide lines to position your images on the pages, and for each image do Insert > Insert Image Frame. Right click inside the resulting frame and select Get Image. (I typically export my images from the GIMP as PNG files, after building them to scale so that at full size they are 300 DPI; i.e. an image 2" x 2" would be 600 x 600 pixels.) Once you have got the image in the frame, right click in the frame again and select Adjust Frame To Image. Then drag and drop the frame into place as indicated by the guide lines you set up earlier.
You can add cut marks using guide lines and the simple drawing tool in Inkscape.
When both pages are done, save the file then export it as PDF @ 300 DPI (or whatever the native resolution of your images is). Open it up with a PDF viewer, check your work, and if possible print a double sided test sheet to verify alignment of the two sides.
That's about all there is to it. If your print vendor has other specifications, Inkscape will be able to accommodate them - but PDF is pretty much universal and expected.
:o)
Steve
2015-10-20 16:46:27 UTC (over 9 years ago)
On 10/20/2015 12:41 PM, Steve Kinney wrote:
No, I don't use Inkscape for the stuff described below. The program is Scribus.
Sory about the brain fart, the rest of the post seems to be correct. Inkscape is a vector editor - one I have spent waaay to much time using lately, making labels for machine tools. :D
Here's the program I "meant to" suggest: http://www.scribus.net/
:o)
Steve
heviiguy
2015-10-21 10:39:51 UTC (over 9 years ago)
I noticed Steve's gracious and very detailed answer. Yet, I did not see a subsequent "thank-you". That was rather disappointing. So, in the effort of maintaining the spirit of altruistic assistance alive, I'll say it: Thanks Steve !
I hope that when I need the inevitable helping hand or push in the right direction somebody as generous as Steve will be there to help. -----Original Message-----
To: gimp-user-list@gnome.org
Subject: Re: [Gimp-user] How to use bleed and cropping: BIG correction Date: Tue, 20 Oct 2015 12:46:27 -0400 On 10/20/2015 12:41 PM, Steve Kinney wrote: No, I don't use Inkscape for the stuff described below. The program is Scribus.
Sory about the brain fart, the rest of the post seems to be correct. Inkscape is a vector editor - one I have spent waaay to much time using lately, making labels for machine tools. :D Here's the program I "meant to" suggest: http://www.scribus.net/
:o)
Steve
gimp-user-list mailing list
List address:    gimp-user-list@gnome.org
List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
List archives:   https://mail.gnome.org/archives/gimp-user-list
Sebastian McShane
2015-10-21 10:53:07 UTC (over 9 years ago)
How do I stop getting all of these Gimp emails?
SentfrommyBlackBerry10smartphone. Original Message
Sent: Wednesday, October 21, 2015 6:40 AM To: Steve Kinney; gimp-user-list@gnome.org Subject: Re: [Gimp-user] How to use bleed and cropping: BIG correction
:o)
Steve
Douglas Ray
2015-10-21 13:28:36 UTC (over 9 years ago)
I've just installed the native os-x download of GIMP 2.8.14.
(previous GIMP experience solely on linux / bsd, so I can't compare with earlier OS-X GIMPs)
Couldn't get text to display.
The text tool outlines a box, but typed text doesn't show. The text *does* show up in the layer label on the layer control panel. I hadn't altered any colours, text foreground was still default black.
Project is grayscale (blank canvas created as grayscale 600ppi), with a couple of images pasted in / rescaled.
Am I missing something?
Thanks, Douglas
2015-10-21 18:38:15 UTC (over 9 years ago)
At the bottom of every email is a "list membership" link:
Near the bottom of that page is a box to enter your email address, and a button to "unsubscribe or edit options".
Mark.
Liam R E Quin
2015-10-21 20:26:44 UTC (over 9 years ago)
A guess: at 600ppi the default text size may be so small you can't see it; try changing the font size to pt instead of px in Tool Options, and increase it to, say, 24pt.
Liam
Douglas Ray
2015-10-21 22:13:09 UTC (over 9 years ago)
Thanks, Liam,
spot on. With the familiar "18" and p*, I'd missed that it was px rather than pt.
Douglas
Liam
