How to import a raw camera file with color depth greater than 8
How to import a raw camera file with color depth greater than 8 Helmut Jarausch 09 Sep 19:36
  How to import a raw camera file with color depth greater than 8 Pat David 09 Sep 19:37
  How to import a raw camera file with color depth greater than 8 Alexander Rabtchevich 09 Sep 19:53
Helmut Jarausch
2015-09-09 19:36:13 UTC (over 9 years ago)
I have a Lumix camera which (probably) stores 12 bits per color. How can I import such a raw file with this color depth. I'm using the GIT version of GIMP which supports greater color depths.
Many thanks for a hint, Helmut
Pat David
2015-09-09 19:37:23 UTC (over 9 years ago)
You will need UFRaw or some other raw processor to generate a high-bit depth tif, first, then load that.
2015-09-09 19:53:35 UTC (over 9 years ago)
Hi, Helmut. Try darktable from darktable.org.
With respect, Alexander Rabtchevich
