[Fwd: Re: Text tool problem]
[Fwd: Re: Text tool problem] Balas Mark 19 Oct 10:40
Balas Mark
2004-10-19 10:40:30 UTC (over 20 years ago)
Hi!
As I said before, I have a serious problem with the text tool: after selecting it and start typing anything, GIMP closes its windows and exits. Last time I wasn't able to answer every questions:
Sven Neumann wrote:
It would probably help to start gimp from an xterm (or whatever terminal emulator you prefer) and check if there's any output on the console.
The output is the following:
[trychydts@localhost trychydts]$ /usr/local/bin/gimp
(gimp:2212): GLib-GObject-WARNING **: invalid uninstantiatable type `' in cast to `GimpConfigInterface'
(gimp:2212): Gimp-Config-CRITICAL **: file gimpconfig-utils.c: line 300 (gimp_config_sync): assertion `GIMP_IS_CONFIG (src)' failed
(gimp:2212): GLib-GObject-CRITICAL **: file gobject.c: line 1319 (g_object_ref): assertion `G_IS_OBJECT (object)' failed
(script-fu:2213): LibGimpBase-WARNING **: script-fu: wire_read(): error Segmentation fault (core dumped)
I guess that your problem is a somewhat broken font that causes problems with the libraries that handle fonts for GIMP. Does this happen with whatever font you choose?
I haven't tried all, beacause I have about 300 fonts installed, but it seems to be the case.
What versions of freetype and
fontconfig are you using?
Freetype 1.3.1, fontconfig 2.2.1
Mark Balas
