Problem with unsharp-mask
Problem with unsharp-mask Gerald Brosseau 06 May 17:31
  Problem with unsharp-mask Liam R. E. Quin 07 May 05:07
   Problem with unsharp-mask Gerald Brosseau 07 May 11:08
    Problem with unsharp-mask Liam R. E. Quin 07 May 23:55
Gerald Brosseau
2015-05-06 17:31:53 UTC (almost 10 years ago)
Under Kubuntu 15.4
I'm not able anymore to use unsharp-mask. I always receive the same error message :
The program 'gimp' received an X Window System error. This probably reflects a bug in the program. The error was 'BadWindow (invalid Window parameter)'. (Details: serial 20405 error_code 3 request_code 18 minor_code 0) (Note to programmers: normally, X errors are reported asynchronously; that is, you will receive the error a while after causing it. To debug your program, run it with the --sync command line option to change this behavior. You can then get a meaningful backtrace from your debugger if you break on the gdk_x_error() function.)
(unsharp-mask:3176): LibGimpBase-WARNING **: unsharp-mask: gimp_wire_read(): error
(script-fu:3159): LibGimpBase-WARNING **: script-fu: gimp_wire_read(): error
Is it a new problem due to Kubuntu packages?
Gérald Brosseau
La Photo Du Jour
(www.gb-photodujour.com)
Sur internet depuis 1998
Liam R. E. Quin
2015-05-07 05:07:48 UTC (almost 10 years ago)
On Wed, 2015-05-06 at 13:31 -0400, Gerald Brosseau wrote:
Under Kubuntu 15.4
If you run
/usr/lib64/gimp/2.0/plug-ins/unsharp-mask
(you may need to use "locate unsharp-mask" and run the program wherever it happens to be -- not as rot, of course)
you should get a message, /usr/lib64/gimp/2.0/plug-ins/unsharp-mask is a GIMP plug-in and must be run by GIMP to be used
Do you get such a message?
Liam
Gerald Brosseau
2015-05-07 11:08:26 UTC (almost 10 years ago)
When I do :
/usr/lib/gimp/2.0/plug-ins/unsharp-mask
I receive this message :
/usr/lib/gimp/2.0/plug-ins/unsharp-mask is a GIMP plug-in and must be run by GIMP to be used
Under Kubuntu 15.4
If you run
Liam
Gérald Brosseau
La Photo Du Jour
Liam R. E. Quin
2015-05-07 23:55:39 UTC (almost 10 years ago)
On Thu, 2015-05-07 at 07:08 -0400, Gerald Brosseau wrote:
When I do :
OK, so is this the kubuntu-packaged version of GIMP? And have you installed all updates and restarted the system?
Under Kubuntu 15.4
If you run
Liam
function.)
