Set radius for curcular text path?
Set radius for curcular text path? AlphaCat 25 Mar 18:37
  It can be done! AlphaCat 25 Mar 21:40
  Set radius for curcular text path? Joao S. O. Bueno 26 Mar 13:33
2015-03-25 18:37:40 UTC (about 10 years ago)
I use GIMP 2.8.14 in Windows 8.1. I've finally been able to get text to follow a curved path (having happened upon one of the contradictory explanations that actually works), but once the text outline appears along the path, its distance from the path appears to be a random phenomenon. This has worked fine for moderately curved text paths. However, I am trying to get text to follow a concentric circle around a circular object, but the text outline appears impossibly far from the object. I cannot figure out how to control the radius of the concentric text path. Is this possible using the Paths tool, or do I need a script? If that is the case, what script do I need?
Thank you.
2015-03-25 21:40:16 UTC (about 10 years ago)
It can be done!
Never mind. I have done some more digging and found the script I needed: text-along-path-0.4.py
It is a fine thing.
It can be downloaded from this page: http://sourceforge.net/projects/gimp-path-tools/files/scripts/
Thank you.
Joao S. O. Bueno
2015-03-26 13:33:11 UTC (about 10 years ago)
If you are trying to use this kind of effect, it is hardly to tell GIMP is the right tool for the job - You should create your text outlines in a vector based program - like Inkscape - for instance,
and paste them in GIMP for pixel based effects, if desired.
There _are_ ways of creating this effect in GIMP, as you found-out for yourself, but adjusting the
created path/text is always cumbersome. In Inkscape it is even possible to live-edit the text along a circle.
Thank you.
-- AlphaCat (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
