Converting from Indexed to RGB without smoothing the edges
Converting from Indexed to RGB without smoothing the edges Alessandro Francesconi 05 Nov 09:36
  Converting from Indexed to RGB without smoothing the edges Michael Schumacher 05 Nov 09:56
2014-11-05 09:36:01 UTC (over 10 years ago)
Don't know if it's a bug or a feature.... but I need an explanation about this behavior: I have a small icon with an indexed color palette: https://cloud.githubusercontent.com/assets/9453825/4901180/1d1cd216-642f-11e4-97db-4f3a76ffdd7c.png
You see, the edges of the icon are very sharp... but if I convert it to RGB using the "Change mode" menu, the edges become smooth. I don't want this to happen but the "gimp-image-convert-rgb" procedure doesn't take any option or parameter for this.
Why does GIMP automatically smooth the edges when changing to RGB? Thank you!
Ale
2014-11-05 09:56:43 UTC (over 10 years ago)
Von: "Alessandro Francesconi"
Actually, that is the bug in GIMP:
The image uses an indexed palette and an alpha channel. In GIMP 2.8, this limits the alpha to binary, i.e. fully opaque or fully transparent. If you look at the image in other application, it is smooth there already.
When you change the mode to RGB, the alpha channel is displayed as it is supposed to be.
