How do I insert text?
How do I insert text? Paul_Mccarthy 07 Oct 04:05
  [SPAM?] How do I insert text? Gunold Brunbauer 07 Oct 05:53
   Game of GIMP Gunold Brunbauer 07 Oct 17:35
  How do I insert text? Steve Kinney 07 Oct 23:36
2014-10-07 04:05:07 UTC (over 10 years ago)
Hi everyone,
As hard as I try to follow tutorials etc, I can't see text when I try to add it to a photo.
The Help file within Gimp suggests that if I select the Text tool and click on an area of the canvas, I should see text as soon as I start typing.
The text comes up in the "Layers - Brushes" sidebar and I can see a cursor moving in the text box on the canvas, but I see no text on the canvas at all.
What am I doing wrong?
Thanks, Paul
Gunold Brunbauer
2014-10-07 05:53:03 UTC (over 10 years ago)
Am 07.10.2014 um 06:05 schrieb Paul_Mccarthy:
Hi everyone,
Thanks, Paul
Maybe you are working on a wrong layer ??? Gunold (www.bilderstroeme.de)
Gunold Brunbauer
2014-10-07 17:35:05 UTC (over 10 years ago)
Game of GIMP
I think GIMP deserves some promotion. Thats why I implemented a "Game of GIMP". You can find it here: http://www.bilderstroeme.de/gameOfGimp. I hope you have fun and use it to promote gimp. I would like to make a version for android and iphones, too, but I don't have a developer-account. So I'm looking for someone who could be able to put such a version into the aplle store or into th google play store. Thanks,
Gunold
2014-10-07 23:36:43 UTC (over 10 years ago)
On 10/07/2014 12:05 AM, Paul_Mccarthy wrote:
Hi everyone,
That's quite bizarre - there is no connection between the Brushes dialog and the text tool - if you see a moving cursor on the image canvas, nothing should happen anywhere else while you type. My first impulse would be to check whether I had the current stable version of the GIMP from an "official" source - and even if so, I would reinstall it anyway just to make certain.
If you don't see the text appearing in in the image as you type, that might be because it's too small to see: The larger the image you are adding text to, the harder the letters will be to see, unless you have selected a font & size that are large enough to show up. Next time around try typing something, do Control+a to select what you typed, and increase the size via the on-canvas control box to see what happens. Worth a try anyway.
:o)
Steve
-----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.14 (GNU/Linux)
iQIcBAEBAgAGBQJUNHkLAAoJEDZ0Gg87KR0LAiIP/01EuB/7o5Qe2GpVf9zHWDLL kCv+EowFMtU5bHEaqUm96ODz3bazozP3BD2Wkgvtc1BhZpkmcT4Mg9auQGv/sALv LDsBQMPAxFKaaEq5WkMQYn4y96g0xj+Zu1DljYIS1PefsJ9WT4D9Ms/RbuBoN3qp u53Wt4uOMZFoMIUFlJpgqPAljnyyFG8y+V0XBSvDbRw8lFJ5ZoGS24uS9zHgYTVu 6KqaFHC2uLTlAGzpIr8VuSxLbGiZFiO3SYbKXxparGUopd1NVKN58ePNAQY0/Bs/ F5qI2VYiDW/nV3/0icZXOxnvnggXbfIxPyHXHL44x2v7RqprojZiDvCCiJbae+gM u8df2v9d/Vimr3poSB5z3VnoLXS5yRhwn8qRn9ukauK5es52gLUFQRbk9Aw9G8wt vyN8dljN9GrAbUcsIDsNdyGa0/BQ8cT16nloSON9Q7Ew6o3FEM1eZYulqL0V4Q6y vS1d/MvJOExnMaojL+hovPQOWJbacJX0Sa6cRIZxPmKXR9lXGj6kgMuXd3QZLeEU 2OMatLX/tvZOuVNzNGaLTkeQav71r9uRIxbLQqNNvgljEz+t97o4kQESYgMhgj34 b/Fq1J/kOMjMV4ITyt+JOPx7RuQnzDmgsSRFTVBEsr2JSOBZ8sXuitxb/yfefZQB zF6Jyxw9bLyaL9tX95k9
=fByi
-----END PGP SIGNATURE-----
