gimp unusable?
gimp unusable? Kid Pixel 29 Jul 20:09
  gimp unusable? Alexandre Prokoudine 30 Jul 16:45
Kid Pixel
2014-07-29 20:09:19 UTC (over 10 years ago)
gimp unusable?
all i wanted to do is put black behind a pasted photo, put some text under it.
Gimp made this seemingly impossible, and left dashed boxes everywhere I couldn't remove or work with to accomplish any filling etc. it's a nightmare, whats the deal?
2014-07-30 16:45:36 UTC (over 10 years ago)
gimp unusable?
1. Open your image.
2. Create a new transparent layer
3. Choose rectangular selection tool. 4. Draw a selection aroind the area where you want that black rectangle. Tweak it by grabbing handles inside. Click inside to confirm this is your selection.
5. From the toolbox that is to the left of your image click on the black colored rectangle and drag it inside your selection. 6. Choose the text tool, click on top of your black rectangle and type the text you need.
7. Select this text and in the floating dialog with text settings pick a color for the text.
8. In menu: File -> Export...
Whenever you do something new, try to break your task into smaller logical steps and look for a solution. It does help.
Alex 30 июля 2014 г. 20:35 пользователь "Kid Pixel" написал:
