color a selection
color a selection billn 19 Jul 10:05
  color a selection Owen 19 Jul 10:51
   color a selection billn 19 Jul 14:21
  color a selection Ofnuts 19 Jul 17:11
   color a selection billn 19 Jul 19:36
    color a selection Ofnuts 19 Jul 23:45
2014-07-19 10:05:48 UTC (almost 11 years ago)
color a selection
Sometimes when I made a selection on a layer and try to fill with the paint bucket or drag the foreground color it will not work. Sometime the whole layer will not fill in.
Owen
2014-07-19 10:51:28 UTC (almost 11 years ago)
color a selection
will not fill in.
When you select the Bucket Fill tool, you have in the Tool options,
a. Fill whole selection b. Fill similar colors.
Which one had you selected?
Owen
2014-07-19 14:21:53 UTC (almost 11 years ago)
color a selection
I tried them both and it will not file the layer.
2014-07-19 17:11:06 UTC (almost 11 years ago)
color a selection
A useful check list: When suddenly nothing seems to work anymore...
2014-07-19 19:36:32 UTC (almost 11 years ago)
color a selection
attached is a copy of a file I am playing with and can not get it to full selections.
2014-07-19 23:45:13 UTC (almost 11 years ago)
color a selection
* http://www.gimpusers.com/system/attachments/128/original/gimp_forum.png
The selection applies to the whole image, it is not related to a specific layer. When you paint, the paint goes to the pixels that are both in the selection (more accurately, covered by the selection mask) and, of course, in the active layer. In your image, the selection is completely outside of the active layer ("Excellent screen") so if you try to paint in the selection, you are painting outside your active layer and if you try to pain on "Excellent screen" you are painting outside of the selection. In either case nothing happens.
Depending on what you want to do, select the other layer, or use Layer>Layer to image size to make "Exellent screen" cover the whole canvas.
This is somewhat item 2) in the check list.
