Paint Brush Color
Paint Brush Color Carusoswi 10 May 07:29
  Paint Brush Color Owen 10 May 09:15
2014-05-10 07:29:00 UTC (almost 11 years ago)
Paint Brush Color
I use Gimp in my photography. Until now, that's all I have used it for. Today, I came across a text document in pdf format, and it is probably protected in some way such that my pdf reader cannot highlight anything.
Since it is important that I highlight this document in order to make use of it, I figured I would open it in Gimp, export as tiff, at which point, I should be able to open the tiff file and paint with a semi-transparent brush to highlight sections of text as necessary.
Unfortunately, search though I may, I cannot find in Gimp where one selects or changes the brush color.
I've searched online, and most subjects that come up have to do with how to make brushes. I don't need to design a brush. I just want to bring up a palette that will allow me to paint over the drawing with a red brush, or yellow, etc.
I even opened one of my color photos thinking that there might be a problem with the tiff that I had created, but I cannot find any dialog box that deals with the brush color attribute.
I'm certain the answer is before my eyes, but they are not finding it for me. Advice would be most welcome.
Caruso
Owen
2014-05-10 09:15:42 UTC (almost 11 years ago)
Paint Brush Color
The brush takes the color of the foreground color which can be set up via the swatches
The opacity for the brush is in the Brush Tool Options
Owen
Caruso
Owen
