Is it possible to set the max brush & pen slider values
Is it possible to set the max brush & pen slider values Paul Read 30 Jan 20:31
  Is it possible to set the max brush & pen slider values Brendan Scott 30 Jan 21:21
  Is it possible to set the max brush & pen slider values Gary Aitken 30 Jan 23:58
   Is it possible to set the max brush & pen slider values Paul Read 31 Jan 07:56
Paul Read
2014-01-30 20:31:12 UTC (about 11 years ago)
The sliders are nearly useless for me as I typically use pens and brush sizes of 1,5, 10 and 20. I need to change the size regularly and the sliders would be ideal yet my 'working' range is in a tiny little bit at the end of the slider value.
It would be a huge gain for me to some how set the max slider value to a value of my choice (say 50) rather than the current value of 1000
Is it possible? If not can I make a feature request (and if so how)
Many thanks Paul
http://www.readiescards.co.uk
Brendan Scott
2014-01-30 21:21:54 UTC (about 11 years ago)
If you install my BGII plugin it will allow you to choose brush sizes from a drop down. So, you just add 1, 5, 10 and 20 and they are the only sizes which will be shown in the drop down. You can set a key to cycle through your size presets as well, so you don't even need to use that. BGII does other stuff as well.
The plugin is here: http://registry.gimp.org/node/28413
Regards
Brendan
Gary Aitken
2014-01-30 23:58:23 UTC (about 11 years ago)
There is already a feature request filed for this: https://bugzilla.gnome.org/show_bug.cgi?id=689731
Also see the following old post related to the subject:
https://mail.gnome.org/archives/gimp-user-list/2012-December/msg00055.html
Paul Read
2014-01-31 07:56:55 UTC (about 11 years ago)
Many thanks, comment added to the feature request and plugin installed (very handy!)
ta
