how can I change the existing values of color and alpha ?
how can I change the existing values of color and alpha ? Cristian Secară 04 Dec 11:04
  how can I change the existing values of color and alpha ? Ofnuts 05 Dec 20:57
Cristian Secară
2013-12-04 11:04:08 UTC (over 11 years ago)
I have a plain rectangle with overall c09300c0 RGBA levels. I want to change the alpha channel value from c0 (193) to some other value, for the whole image at once. Or some other color channel.
How can I change the absolute value of a channel ? The color menu has only relative adjustments.
Thank you, Cristi
Cristian Secară
http://www.secarica.ro
2013-12-05 20:57:20 UTC (over 11 years ago)
Thank you, Cristi
To change the alpha value, add a layer mask (initialize by transferring the layer's alpha channel), and bucket fill with the required value.
To change a color channel (say, red): use the Levels tool, select the red channel, and set it value to 0 everywhere by dragging white handle on the bottom scale fully to the right. Then add a layer, set it to "Addition" mode, and paint on it using colors with only a red component.
