problem with mouse and bamboo pad
8 of 8 messages available
problem with mouse and bamboo pad Patrick Shanahan 03 Dec 03:26
  problem with mouse and bamboo pad Jehan Pagès 03 Dec 04:28
   problem with mouse and bamboo pad Brendan Scott 03 Dec 05:17
    problem with mouse and bamboo pad Jehan Pagès 03 Dec 10:24
     problem with mouse and bamboo pad Brendan Scott 03 Dec 10:45
     problem with mouse and bamboo pad Patrick Shanahan 03 Dec 14:26
      problem with mouse and bamboo pad Patrick Shanahan 03 Dec 22:20
       problem with mouse and bamboo pad Jehan Pagès 04 Dec 01:00
Patrick Shanahan
2013-12-03 03:26:09 UTC (over 11 years ago)
openSUSE Tumbleweed
gimp-2.8.8-80.1.x86_64
Just about had heart failure.
Cannot select or draw or crop using my mouse. Then realized that I had my bamboo pad attached and found that it worked.
Will not the pad and mouse work together? or have I stumbled blindly onto a possible bug?
tks,
http://wahoo.no-ip.org        Photo Album: http://wahoo.no-ip.org/gallery2
Jehan Pagès
2013-12-03 04:28:24 UTC (over 11 years ago)
On Tue, Dec 3, 2013 at 4:26 PM, Patrick Shanahan wrote:
openSUSE Tumbleweed
Someone I know just had the same thing. Well I did not think about whether that would be the Wacom (intuos 5 here)'s fault because her tablet is always plugged in. But same, she could not select/draw with her mouse. She could with the laptop's pad and the tablet. I'll see if we can reproduce later.
No that's supposed to work (as 2 separate devices). So that's definitely a bug. If I can reproduce it, I'll try and fix this.
Jehan
tks,
(paka)Patrick Shanahan Plainfield, Indiana, USA @ptilopteri http://en.opensuse.org openSUSE Community Member facebook/ptilopteri http://wahoo.no-ip.org Photo Album: http://wahoo.no-ip.org/gallery2 Registered Linux User #207535 @ http://linuxcounter.net _______________________________________________ gimp-user-list mailing list
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
Brendan Scott
2013-12-03 05:17:04 UTC (over 11 years ago)
openSUSE Tumbleweed
fwiw this my experience (Intuos 5 touch M) as well. I figured I'd done something wrong in the settings.
Jehan Pagès
2013-12-03 10:24:29 UTC (over 11 years ago)
openSUSE Tumbleweed
Well that makes 3 people, which is a pretty good sign there is actually something wrong somewhere. Are you also using GIMP 2.8.8, Brendan? Are you using Linux too?
Unfortunately, we just tried again and have not been able to reproduce. Can any of you reproduce the issue everytime? Or it just happened this one time? If you can reproduce, would you have any reproduction steps for me?
Thanks.
Jehan
Brendan Scott
2013-12-03 10:45:37 UTC (over 11 years ago)
GIMP 2.8.2
Opensuse 12.3
Now that you mention it, no. I can't reproduce it every time.
A: Just now I fired up GIMP, file->new->640x400 Selection and paintbrush worked for both mouse and touchpad.
B: Open a jpg - now neither the selection tool nor the paintbrush tool works for the mouse. The pen works properly though.
C: Switch back to the original new image tab: selection and paintbrush not working for mouse
Close GIMP Open GIMP
D:
repeat A:
mouse not working for _any_ tools I try (to be fair, I only tried selection and paintbrush for A-C earlier though). GIMP still responsive to mouse events though - eg menu, click tabs, quick mask and nav widgets
hope that helps.
Brendan
Patrick Shanahan
2013-12-03 14:26:50 UTC (over 11 years ago)
* Jehan Pags [12-03-13 05:27]:
I had same prob on 2.8.2.
I can reproduce. Open gimp, open jpg or png with tablet and mouse both active and only tablet is functional. Disconnect tablet and mouse is functional.
ps: using rpm packages from distro
Patrick Shanahan
2013-12-03 22:20:18 UTC (over 11 years ago)
* Patrick Shanahan [12-03-13 09:27]:
UPDATE: After restarting X with both devices connected, I no longer have cited problem. Go fingure ????
tks, for your indulgence.
Jehan Pagès
2013-12-04 01:00:48 UTC (over 11 years ago)
* Jehan Pagès [12-03-13 05:27]:
Well same here. I can't reproduce the issue at all. But since 3 people reported what seems like exactly the same issue, with same symptoms, I opened a bug report: https://bugzilla.gnome.org/show_bug.cgi?id=719817 If any of you experience this issue again and manages to find a way to reproduce it every time, please complete the report. That would help to diagnose.
Jehan
