Can't get 2.8.10 to operate correct after building from source
Can't get 2.8.10 to operate correct after building from source Sven Tryding 30 Nov 10:22
  Can't get 2.8.10 to operate correct after building from source Sven Tryding 30 Nov 16:54
  Can't get 2.8.10 to operate correct after building from source Michael Schumacher 30 Nov 16:59
Sven Tryding
2013-11-30 10:22:44 UTC (over 11 years ago)
I have tried to upgrade my gimp2.8.2 (default in debian distrubuted version at the moment) to 2.8.10 since I read through release notes and realized I could be an even happier user with this version. During installation I found that I missed quite a few bits and pieces, but I installed them when required. (babl, gegle, glib2 e.g.). Eventually I reached the make install stage and it seemed to work ok. However when now opening gimp I can't open files and I lack quite a few filters possibly other menues missing I havn't walked into everything yet. It seems like a folders supposed to be created and refreshed in /.gimp2.8 was not.
I am on debian wheezy linux (7.2), xfce4 deskop.
Screenshot when opening gimp and a gimp --verbose consol capture is attached.
Any hints how to fix my gimp build to a proper build would be great.
Thanks Sven
Sven Tryding
2013-11-30 16:54:52 UTC (over 11 years ago)
2013-11-30 11:22, Sven Tryding skrev: After a 'make clean', reinstallation of python2.7 and a rebuild of the whole project, all my issues seems to be resolved.
Br Sven
Thanks Sven
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
2013-11-30 16:59:40 UTC (over 11 years ago)
You can install all the dependencies of the default GIMP package of you distro with a single command:
sudo apt-get build-dep gimp
Then you will only have to worry about any dependencies that are e.g. not the required versions.
