Path Tool Problems
14 of 14 messages available
Path Tool Problems akovia 03 Oct 16:19
  Path Tool Problems Simon Budig 04 Oct 14:30
   Path Tool Problems Akovia 04 Oct 16:41
    Path Tool Problems Simon Budig 04 Oct 22:58
     Path Tool Problems Akovia 04 Oct 23:23
      Path Tool Problems Simon Budig 04 Oct 23:53
       Path Tool Problems Akovia 05 Oct 00:30
        Path Tool Problems Akovia 01 Nov 16:48
         Path Tool Problems Akovia 01 Nov 21:26
          Path Tool Problems Michael Schumacher 02 Nov 14:34
           Path Tool Problems Akovia 03 Nov 13:48
   Path Tool Problems Akovia 04 Oct 21:46
    Path Tool Problems Simon Budig 04 Oct 22:49
     Path Tool Problems Akovia 04 Oct 23:11
akovia
2013-10-03 16:19:42 UTC (over 11 years ago)
Path Tool Problems
I use the path tool in gimp extensively so maybe I'm more sensitive to these nuances, but I wondered if any one else has run into these problems.
1. Can't add intermediate nodes.
There are times when I'll go to add a node between existing nodes and it won't allow me to do so. I have to walk the path until I can find a spot will it will let me and delete all the nodes to that point and build the path again. The last time this happened I had copied a path from a different gimp image and pasted it into my new drawing. I'm not sure if this always follows a paste operation or not, but will try to troubleshoot it further the next time it happens.
2. Node selection precision.
I very often have trouble grabbing a node to move it. It's as if the calibration of my mouse if off as I have to hover in the vicinity of the node till I get the move cursor to show. Sometimes this is very tricky indeed. This can be very annoying when trying to move quickly and I know it's not my mouse as I don't have this trouble in any other program including inkscape.
3. Path strokes.
Quite often on big complicated paths that I try to stroke, there will be a few sharp angles that won't protrude out to a point and will just look like it was cut off. If I add handles or manipulate existing handles a little bit in some way I can usually find a way to get some sort of acceptable result. Conversely, there are times when a sharp inner angle, (like the upper part of the letter "A") will protrude out past the rest of the path stroke and I will have to manually edit the result.
I can't seem to find the determining factors for these behaviors so that I can get predictable results when creating my paths.
Any insight on these problems would be most helpful.
Many Thanks.
-- akovia
http://www.fastmail.fm - Send your email first class
Simon Budig
2013-10-04 14:30:13 UTC (over 11 years ago)
Path Tool Problems
Make sure the path is "connected" to the path tool, e.g. by doubleclicking the path in the path dialog.
I designed the path tool to "usually" stay in Design mode. Then you can use Control to temporarily switch to Edit mode. Edit-mode on-top of a path segement should show a small "+" at the mouse cursor, clicking will result in adding a node at this point.
Control+Shift will be Edit-Mode plus "subtract/remove" - i.e. ctrl-shift-clicking on top of a node will remove it, ctrl-shift-clicking on a segment will open up the path by removing the segment.
No idea about that one. I don't think I've seen that.
3. Path strokes.
Do you stroke with a tool? Or by "stroke line"? with which options? For the Mitre-Join the Mitre-Limit determines the amount of "allowed protrusion".
Can you provide screenshots of the problematic results?
Thanks, Simon
simon@budig.de              http://simon.budig.de/
Akovia
2013-10-04 16:41:43 UTC (over 11 years ago)
Path Tool Problems
Simon Budig wrote
akovia (
akovia1@
Yes to all above. I am very familiar with all the modifiers. If I hover my mouse above a certain segments holding Control, some segments will allow to add a node, while other segments won't. This also effects deleting line segments.
Now that I think about it I have the last instance on video from a tutorial I made. It's kinda perfect since I have it showing my key-presses as well. https://dl.dropboxusercontent.com/u/93550827/Gimp%20Tutorial%20Series/he-is-my-master_full.mkv 6:35 to around 8:30 is the problem. I also realized that this also was a copied and pasted path.
I will try to capture this as well and post a screenshot or video.
3. Path strokes.
Stroke line mostly unless I'm after some sort of effect. Playing with the mitre setting does have some effect on the problem. Maybe I just can't get the expected results I want in having an even stroke all the way around. Have a look at this and maybe you can explain if there is another way. For now I have just been patching some paths together to get what I need.. https://dl.dropboxusercontent.com/u/93550827/temp/path-stroke_mitre.mkv
-- View this message in context: http://gimp.1065349.n5.nabble.com/Path-Tool-Problems-tp40365p40396.html Sent from the Users mailing list archive at Nabble.com.
Akovia
2013-10-04 21:46:15 UTC (over 11 years ago)
Path Tool Problems
Ok I just ran into this. This isn't a worst case as sometimes the move icon is even further away than this.
It does appear to be affected by the zoom level which I never noticed before. I usually zoom in further which normally fixes things, but this time I noticed that zooming out can also recalibrate the mouse pointer.
Maybe this will help. https://dl.dropboxusercontent.com/u/93550827/temp/Gimp%20Node%20Precision.mkv
-- View this message in context: http://gimp.1065349.n5.nabble.com/Path-Tool-Problems-tp40365p40404.html Sent from the Users mailing list archive at Nabble.com.
Simon Budig
2013-10-04 22:49:00 UTC (over 11 years ago)
Path Tool Problems
I strongly suspect that in this case the behaviour is caused by the guides. The "hot spot" of the mouse cursor is dragged towards the guide (within the snapping distance) and hence the click does not happen at the anchor.
Not sure if this is fixable, since placing new points along a guide is a desireable behaviour as well.
Try to disable snapping.
Bye, Simon
Simon Budig
2013-10-04 22:58:05 UTC (over 11 years ago)
Path Tool Problems
Hmm. Is this usually happening when having a huge zoom level?
There is a funky problem there: for determining the closest point along a bezier the bezier segment is approximated by line segments to a certain precision. The precision used does not take the zoom level into account. This is usually no problem, since it is < 1 pixel and "close enough" for the usual zoom levels.
However there are corner cases in huge zoom levels, where the (invisible) line approximation is off by a significant fraction of a pixel, so that the net result is an active area disconnected from the drawn bezier segment. You can verify this by searching on the "inside" of the curved bezier segment for an active area.
I'd consider this a bug that might have been introduced when we introduced cairo-based rendering for the tool graphics (earlier the drawn path used the same line approximation as the detection code).
Probably a bit tricky to fix...
Bye, Simon
Akovia
2013-10-04 23:11:11 UTC (over 11 years ago)
Path Tool Problems
segments
Weird.
Right?
tutorial
Really weird. I cannot reproduce this here though. *shrug*
Where did you copy/paste the path from? Inkscape?
Earlier the video you can see that I copied it from another gimp drawing.
Ok, I think what you're seeing there is expected behaviour. The problem is, that when you move two tangents closely together (i.e. you have a very sharp corner) the end point of the stroke moves towards infinity, i.e. you need to cap this at some point. The parameter controlling this is the mitre limit. We use cairo for rendering and the behaviour is described as follows in the cairo documentation:
If the current line join style is set to CAIRO_LINE_JOIN_MITER (see cairo_set_line_join()), the miter limit is used to determine whether the lines should be joined with a bevel instead of a miter. Cairo divides the length of the miter by the line width. If the result is greater than the miter limit, the style is converted to a bevel.
The default miter limit value is 10.0, which will convert joins with interior angles less than 11 degrees to bevels instead of miters. For reference, a miter limit of 2.0 makes the miter cutoff at 60 degrees, and a miter limit of 1.414 makes the cutoff at 90 degrees.
A miter limit for a desired angle can be computed as: miter limit = 1/sin(angle/2)
There is no way to completely disable the miter limit, but maybe the range of the limit in the UI is not sufficient.
I hope this helps, Simon
I will play around with the mitre limit some more and see what I can come up with. Thanks for the tips.
Simon Budig wrote
Akovia (
akovia1@
) wrote:
Simon Budig wrote
akovia (
akovia1@
Bye, Simon
That just might be possible. It never occurred to me since there is no visible snapping of the mouse. I will check that for sure the next time it happens and report back. I really hope that's it. Thanks
View this message in context: http://gimp.1065349.n5.nabble.com/Path-Tool-Problems-tp40365p40411.html Sent from the Users mailing list archive at Nabble.com.
Akovia
2013-10-04 23:23:24 UTC (over 11 years ago)
Path Tool Problems
Simon Budig wrote
Akovia (
akovia1@
Not really. Like I said, sometimes I can "walk" the path and find where I can insert or delete as normal. I do this at the same zoom level. It's like the path got corrupted and I have to delete the corrupted part of the path and rebuild it, then everything works fine again.
Bye, Simon
I'm wondering if my clipboard manager isn't screwing things up. I discovered a problem within inkscape that is apparently affected by it and everything works as it should when I turn it off. Can you discern anything from this bug report that might affect gimp as well?
https://bugs.launchpad.net/inkscape/+bug/418242
I will try disabling my clipman next time and repeat the copy+paste to see what happens.
View this message in context: http://gimp.1065349.n5.nabble.com/Path-Tool-Problems-tp40365p40413.html Sent from the Users mailing list archive at Nabble.com.
Simon Budig
2013-10-04 23:53:41 UTC (over 11 years ago)
Path Tool Problems
Well, the path data structure is unlikely to be corrupted in a way that could have these effects. *If* it gets corrupted this'd more likely mean that GIMP would crash. The data used for locating the mouse pointer is the same as the data used for drawing, the only plausible difference to me is the precision. But this is always better than 1 image-pixel.
Hrm.
Bye, Simon
Akovia
2013-10-05 00:30:19 UTC (over 11 years ago)
Path Tool Problems
Simon Budig wrote
Akovia (
akovia1@
Hrm.
Inspecting the structure of an svg convinces me you're right about corruption not being the issue. I don't see how it could produce the results I'm seeing.
If memory serves (no guarantees), I didn't see this before 2.8, so you are probably right about the cairo connection. Would you like me to send you the xcf the next time it happens?
-- View this message in context: http://gimp.1065349.n5.nabble.com/Path-Tool-Problems-tp40365p40416.html Sent from the Users mailing list archive at Nabble.com.
Akovia
2013-11-01 16:48:00 UTC (over 11 years ago)
Path Tool Problems
This just creeped up again. I can add nodes between certain node pairs, but not others.
I made this path by joining two paths, then was going back to round the corners.
Happens with guides on or off and at any zoom level.
Here is a small vid of it. https://dl.dropboxusercontent.com/u/93550827/temp/Path-add-nodes.mkv
I'm happy to up the xcf if you think it will help. Cheers
View this message in context: http://gimp.1065349.n5.nabble.com/Path-Tool-Problems-tp40365p40672.html Sent from the Users mailing list archive at Nabble.com.
Akovia
2013-11-01 21:26:14 UTC (over 11 years ago)
Path Tool Problems
and I also keep getting stroke problems as well where it will be an inconsistent broken up stroke.
https://dl.dropboxusercontent.com/u/93550827/temp/path%20stroke.mkv
The path was all made in the xcf and no merging or copy+paste was involved.
-- View this message in context: http://gimp.1065349.n5.nabble.com/Path-Tool-Problems-tp40365p40679.html Sent from the Users mailing list archive at Nabble.com.
2013-11-02 14:34:41 UTC (over 11 years ago)
Path Tool Problems
Am 01.11.2013 22:26, schrieb Akovia:
Can you convert this video to a different codec, e.g. Theora? H.264 doesn't work here.
P.S. also see http://xiphmont.livejournal.com/61927.html about why it may be a good idea to avoid H.264 altogether.
Akovia
2013-11-03 13:48:44 UTC (over 11 years ago)
Path Tool Problems
