Background help 101
Background help 101 glenda wright 25 Sep 00:51
  Background help 101 Liam R E Quin 25 Sep 00:55
  Background help 101 Burnie West 25 Sep 02:30
glenda wright
2013-09-25 00:51:17 UTC (about 12 years ago)
Background help 101
How do I get a clean white background with GIMP when displaying items on my website?
Glenda Wright
Liam R E Quin
2013-09-25 00:55:38 UTC (about 12 years ago)
Background help 101
I think we'd need to know a lot more about what exactly you are doing. GIMP in itself is not related to displaying items in a Web site... are you using some sort of Web gallery plugin? Or what?
Liam
Burnie West
2013-09-25 02:30:40 UTC (about 12 years ago)
Background help 101
It depends on your objective and your starting point. If you can clearly identify the area you want to be background, then remove it from the image. This might need you to use the lasso tool to outline the background, which might take some time - especially if it is in pieces.
If the background color is set to white (the default state) then exporting to jpg will produce your image with a white background.
If, however, you want the background to be the default background of your image (rather than simply "white"), you should add an alpha channel to the image, then remove the area that is supposed to be background (it will show up as a light-gray/dark-gray checkerboard), and export the picture to png.
If this doesn't help, perhaps you might rephrase your question. Some of the tutorials might also help.
