using GIMP jpegs in OpenOffice Writer - error
using GIMP jpegs in OpenOffice Writer - error Uniklaps 04 Sep 12:00
  using GIMP jpegs in OpenOffice Writer - error Gunold Brunbauer 04 Sep 13:09
  using GIMP jpegs in OpenOffice Writer - error Gary Aitken 04 Sep 16:28
  using GIMP jpegs in OpenOffice Writer - error Ofnuts 04 Sep 17:49
   using GIMP jpegs in OpenOffice Writer - error Tom Williams 04 Sep 17:57
    using GIMP jpegs in OpenOffice Writer - error Uniklaps 04 Sep 19:39
Uniklaps
2013-09-04 12:00:21 UTC (over 11 years ago)
Win 7 64 bit RAM 16 GB GIMP 2.8.4
Hi friends,
with GIMP I create maps using a WACOM tablet. I save the data as xcf, additional using the export option as jpg and tif. These files Jpg and tif are for further use. If I try to insert one of these jpgs, OpenOffice Writer (3.4.1) show an error report "graphic filter not found" (translated from german)
If I open the GIMP jpg with Photoshop elements and save it again as jpg either overwriting the old file from GIMP-export or creating a new file (copy) , OO Writer shows the same error-report; same reaction with the GIMP tif.
But if I open the GIMP jpg or GIMP tif with PhotoLine (V 17.11; Shareware; demo free
www.pl32.de) and save it again als jpg (highest qualitiy) then OO Writer insert this picture.
Is this behaviour caused by GIMP or OO Writer or are both "guilty" or is this a bug ?
Is there a way to persuade GIMP to export a readable jpg ??
Thanks for all your help!
Konrad
Gunold Brunbauer
2013-09-04 13:09:15 UTC (over 11 years ago)
Hello Konrad,
I often exported a GIMP-Picture as jpg or gif and imported it in OpenOffice Writer (Version 4.0.0). There was never any problem. I think there is a problem in your installation. I would say you should install OpenOffice 4.
Gunold
- www.bilderstroeme.de -
Am 04.09.2013 14:00, schrieb Uniklaps:
Hi friends,
Konrad _______________________________________________ gimp-user-list mailing list
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
Gary Aitken
2013-09-04 16:28:27 UTC (over 11 years ago)
Hi friends,
Hi Konrad,
I am using OO 3.4.1 on FreeBSD and GIMP 2.8.6. I have no trouble inserting .jpg files output from gimp into OO Writer. I also had no trouble when using OO 3.3.x.
How big are these files, and is there any chance you are simply running over some memory / address space limits? I know once upon a time there were issues of this sort in windows environments when the 4G limit was reached. Since you are running windows, is the OO you are running a 32 bit version, and not able to make use of the whole address space? What happens if you use smaller images, or export using a lower quality jpg?
Gary
2013-09-04 17:49:37 UTC (over 11 years ago)
Hi friends,
In the advanced options of the JPEG save dialog, un-tick the "Progressive" box. it is known to cause problems. If I guessed right you can file a bug with OpenOffice because it really should support that feature...
Tom Williams
2013-09-04 17:57:20 UTC (over 11 years ago)
I was able to import a JPEG I exported in Gimp on Linux _with_ the "Progressive" option enabled into a document I created in LibreOffice 4.0.4.2 on Linux just fine.
Perhaps there was an issue with previous versions of OpenOffice.
Peace...
Tom
/When we dance, you have a way with me,
Stay with me... Sway with me.../
Uniklaps
2013-09-04 19:39:08 UTC (over 11 years ago)
Hi Tom,
hi ofnuts -- [ what a first name :-) ]
Great, thank you both, this worked!
Konrad
-----Ursprngliche Nachricht-----
Von: gimp-user-list [mailto:gimp-user-list- bounces@gnome.org] Im Auftrag von Tom Williams Gesendet: Mittwoch, 4. September 2013 19:57 An: gimp-user-list@gnome.org
Betreff: Re: [Gimp-user] using GIMP jpegs in OpenOffice Writer - error
un-tick the
If I guessed right
that feature...
Peace...
Tom
-- /When we dance, you have a way with me, Stay with me... Sway with me.../
__________________________________________ _____
https://mail.gnome.org/mailman/listinfo/gimp-user- list
