gimp long opening after changing the settings
gimp long opening after changing the settings gimp@jbmd.com 04 Jul 08:32
  gimp long opening after changing the settings Richard Gitschlag 04 Jul 13:40
gimp@jbmd.com
2013-07-04 08:32:20 UTC (almost 12 years ago)
I changed settings in GIMP program, specifically the path to the palletes. Right after that GIMP started opening many minutes. Then I changed the path to the original one (didnt help), then I uninstalled and installed and it is still taking for ages to open this program. I am desperate. Should I edit registry or what should I do?
Thank you for any advice.
pm
Richard Gitschlag
2013-07-04 13:40:25 UTC (almost 12 years ago)
Date: Thu, 4 Jul 2013 10:32:20 +0200 From: gimp@jbmd.com
To: gimp-user-list@gnome.org
Subject: [Gimp-user] gimp long opening after changing the settings
pm
If we had a dollar for every time somebody thinks uninstalling/reinstalling will ever solve anything....
There seems to be an issue in GIMP 2.8.6 with plugins during its startup routine where it manually queries every plugin at every startup (instead of just checking for new/updated plugins like it should do).
