A sad case of regression ?
12 of 14 messages available
A sad case of regression ? Renaud OLGIATI 14 Jun 11:31
  2EBBE4889ADF4C4B88353D913C4... 14 Jun 17:23
   A sad case of regression ? Renaud OLGIATI 14 Jun 17:21
    CAFmbb2b5xxrkwTXRDEGota7Hdg... 15 Jun 02:37
     A sad case of regression ? Helen 15 Jun 02:37
      A sad case of regression ? Liam R E Quin 16 Jun 03:30
    A sad case of regression ? Alexandre Prokoudine 14 Jun 17:43
     A sad case of regression ? Renaud OLGIATI 14 Jun 18:04
      A sad case of regression ? Alexandre Prokoudine 14 Jun 18:14
       A sad case of regression ? Alexandre Prokoudine 14 Jun 18:15
  A sad case of regression ? Alexandre Prokoudine 14 Jun 11:56
  A sad case of regression ? Richard Gitschlag 14 Jun 14:28
  Technical issues with recent mails (was: Re: A sad case of regression ?) Michael Schumacher 15 Jun 12:34
   Technical issues with recent mails (was: Re: A sad case of regression ?) Alec Burgess 15 Jun 21:54
Renaud OLGIATI
2013-06-14 11:31:46 UTC (over 12 years ago)
Although I have been using GIMP for fourteen years, since release 1.0, I am new to 2.8.
I have noticed a change in the behaviour of the load/save process which seems to me to be a bad regression, unless it can be bypassed by a change in the configuration.
In the past, I would open, say, a .jpeg file, work on it, and when the time came to Save, it would by default be saved in the file format of the original file.
Now, Save (and Save As) only offers me .xcf (and archived .xcf), if I want to save in the original file format I have to go through Export, and then, to add insult to injury, GIMP complains when I close the picture that it has not been saved ! All this seems to me not only a stupid complication, but also deeply counter-intuitive.
Questions:
- Can this behaviour be changed in the configuration of GIMP ?
- If not, what is the latest release of GIMP that behaved in the old (and intuitive) way, so I can go back to that version ?
Cheers,
Ron.
PS Why do the developpers think we all want to use the .xcf format ?
Never explain -- your friends do not need it
                and your enemies will not believe you anyway.
                                            -- Elbert Hubbard
                   -- http://www.olgiati-in-paraguay.org --
2013-06-14 11:56:40 UTC (over 12 years ago)
No
2.6.11
We don't think so.
Richard Gitschlag
2013-06-14 14:28:57 UTC (over 12 years ago)
Here we go again . . . .
It's not like that. It's a change in design from one model to another.
The change is beneficial when you ARE working on an XCF file (in the exact same vein as using Photoshop to work on PSD files, e.g. multi-layer digital compositions). Prior to 2.8 when you "Saved" to something other than an XCF you were constantly warned about things that had to happen (e.g. flattening layers) before GIMP could actually output the file. After that, GIMP lost track of the XCF file, meaning that any subsequent "Save" commands targetted the most recent (non-XCF ) file and if you didn't manually save back to the XCF file before quitting, you could potentially lose edits.
The upside is that Exporting to standard image formats is actually faster in 2.8 than Saving to them was in 2.6 .
The downside is that the change is indeed annoying when all you need GMP for is to open up an image, make a few edits then save back to it, because this does not make GIMP consider the image "Saved" (to an XCF) and you get an extra "Save changes?" prompt when closing the image.
(I also personally disagree with the developer's insistence that GIMP should not give the user an option to switch from the Save dialog to the Export dialogue or vice versa.)
But enough of that. Search the mailing list archives sometime and you will find literally thousands of posts on the Save/Export topic (if the search below is to be believed, in fact over THIRTY THOUSAND): http://www.google.com/custom?q=save+export&domains=mail.gnome.org&hq=inurl%3A%2Farchives%2F&sitesearch=mail.gnome.org
Try giving it a month or two to mentally adjust to selecting "Export" instead of "Save" when you need to output a standard image file format. If you still prefer the old behavior, there are alternatives, such as the "noxcf" fork that preserves the 2.6-style saving behavior:
https://github.com/mskala/noxcf-gimp#readme
Renaud OLGIATI
2013-06-14 17:21:18 UTC (over 12 years ago)
On Fri, 14 Jun 2013 14:28:31 +0200 "Uniklaps" wrote:
When you open a jpg-file in GIMP 2.8 and make changes and save this again as jpg, you cannot re-change the changes you made (if file is closed). If changes are not necessary, GIMP can save as tif or jpg. (But are you always sure, that your work is perfect?)
Saving the jpg you worked with as an GIMP xcf-file you can open it again and continue your work or go back to changes you made. With an jpg this is not possible. But: You should be familiar to the GIMP - feature "layers"
Let us put it this way: If I thought I might want to undo/modify changes later, I would Save As (or Save As Copy) in .xcf; but when I load a .jpg, work on it, and Save, I know that I wont be able to undo changes, and I expect the saved file to replace the original one, not to have the original left untouched and something completely different saved.
Andrew & Bridget wrote:
Just because a program does not perform the way you would like it to, doesn't make it an inferior program.
No, but it makes it more difficult, and less appealing, to use.
As it has been said before if you don't like it, use something else, no body makes you use GIMP.
I like GIMP, have liked it for fourteen years; I just dont like GIMP 2.8,
2.6.11
I will be now be looking for the 2.6.11 package since you kindly tols me it is free from that export/save sillyness.
radar.map35@free.fr wrote:
but if Gimp is made easier and safer for most of people, let's trust our contributors.
Since Linux is all in favour of freedom of choice, how about offering the user an export / save choice in the Preferences dialogues ?
Cheers,
Ron.
Il est dangereux d'avoir raison dans des choses
               où des hommes accrédités ont tort.
                                                   -- Voltaire
2013-06-14 17:43:17 UTC (over 12 years ago)
It's just a kernel. Software neither feels, nor judges, nor favours.
As already discussed before, the answer is 'no'.
Renaud OLGIATI
2013-06-14 18:04:04 UTC (over 12 years ago)
Why not ?
Do I sense here a case of the Microsoft delusion ? ("We are Gimp of Borg, resistance is futile...")
Cheers,
Ron.
PS Could anyone kindly point me in the direction of a repository for a Debian amd64 gimp 2.6.12 deb file ? All my search result have sent me to a gimp.org page that says "This page is obsolete, please see the downloads page. "
A drama critic is a person who surprises a playwright
                       by informing him what he meant.
                                                 -- Wilson Mizner
2013-06-14 18:14:12 UTC (over 12 years ago)
Why not ?
Sorry, but I'm not in a position to explain your senses. There are professionals that do that kind of job for a wide range of fee, as I'm told.
There reason the team doesn't provide a setting for that is because it's a behaviour change. Which is widely regarded by usability engineers as a sure pathway to hell.
http://packages.debian.org/squeeze/gimp
2013-06-14 18:15:08 UTC (over 12 years ago)
(That is, the setting for behaviour change :))
Helen
2013-06-15 02:37:23 UTC (over 12 years ago)
On Fri, Jun 14, 2013 at 9:57 PM, Helen wrote:
I wish to endorse this. The export feature could have been added without disabling the save as feature. And I, also, have tried to go back to gimp 2.6, but now that I have upgraded to suse 12.3, gimp 2.6 will not work with the latest suse gtk
Helen
On Fri, Jun 14, 2013 at 1:21 PM, Renaud OLGIATI < renaud@olgiati-in-paraguay.org> wrote:
again
If
always
sure, that your work is perfect?) Saving the jpg you worked with as an GIMP xcf-file you can open it
again and
not
2.6.11
our contributors.
Cheers,
Ron. --
Il est dangereux d'avoir raison dans des choses o des hommes accrdits ont tort. -- Voltaire
gimp-user-list@gnome.org
Helen Etters
using Linux, suse12.3
Helen Etters
2013-06-15 12:34:48 UTC (over 12 years ago)
Hi there,
I'd like to point of some issues with a few of the recent mails:
1. Broken threading
Some users apparently reply with mail software which breaks threads, e.g. does not add In-Reply-To: / References: headers to sent messages. This starts a new thread for that message. Users 'Crew' and '.', please check your application settings and ensure that replies are threaded properly. The latter user is also advised to change the name part of the mail address, in order to not be caught by many spam filters.
2. Whole messages /mail histories are quoted
When replying to message in a mailing list, please do not quote the entire previous message history. That's what the message archives are for. Reduce the quoted message to the few lines you're referring to.
Let's keep mail a pleasant communications medium a bit longer.
P.S. the mailing lists are configured to remove HTML and attachments from the messages.
HTH,
Alec Burgess
2013-06-15 21:54:16 UTC (over 12 years ago)
I'd noticed the broken threading too and saw this from "." = David Russel
No less than six digests were waiting to be read this morning, almost entirely cluttered with this nonsense.
I think that explains why every message from him starts a new thread (also with subtlety different subject lines). At least he edits his subject so that it doesn't read "Re:[Gimp-user] Digest ....". I don't know any way to maintain threading when participants are receiving digests and this is why I always request individual emails. GMail does a slightly better job of keeping things together but it shows 5 "threads" with respectively 9, 1 (this one), 32, 25 and 18 each.
Regards ... Alec (buralex@gmail& WinLiveMess - alec.m.burgess@skype)
1. Broken threading
Liam R E Quin
2013-06-16 03:30:41 UTC (over 12 years ago)
Control-shift-e (export to) works like the old "save as" for non-xcf formats.
Liam
